требует libc6 >= 2.34
Вы не знаете в какой раздел задать вопрос? Ищите ответы на популярные вопросы? Тогда вам сюда!
z6785
Сообщение z6785 » 26 июн 2022, 18:30
Linux Mint 20.3 Una x64, MATE
Kernel: 5.4.0-121-generic x86_64 bits: 64 compiler: gcc v: 9.4.0
Desktop: MATE 1.26.0 Distro: Linux Mint 20.3 Una base: Ubuntu 20.04 focal
Type: Laptop System: Timi product: TM1703 v: XMAKB3M0P100B
serial: <filter>
Mobo: Timi model: TM1703 v: XMAKB3M0P100B serial: <filter> UEFI: Insyde
v: XMAKB3M0P100B date: 03/22/2018
ID-1: BAT0 charge: 24.4 Wh condition: 30.9/40.1 Wh (77%)
model: SUNWODA R13B02W status: Discharging
Device-1: hidpp_battery_0 model: Logitech M350 Wireless Mouse
charge: 100% (should be ignored) status: Discharging
Topology: Quad Core model: Intel Core i5-8250U bits: 64 type: MT MCP
arch: Kaby Lake rev: A L2 cache: 6144 KiB
bogomips: 28800
Speed: 800 MHz min/max: 400/3400 MHz Core speeds (MHz): 1: 800 2: 798
3: 800 4: 800 5: 800 6: 798 7: 800 8: 800
Device-1: Intel UHD Graphics 620 vendor: Xiaomi driver: i915 v: kernel
bus ID: 00:02.0
Device-2: NVIDIA GP108M [GeForce MX150] vendor: Xiaomi driver: nvidia
v: 470.129.06 bus ID: 01:00.0
Display: x11 server: X.Org 1.20.13 driver: modesetting,nvidia
unloaded: fbdev,nouveau,vesa resolution: 1440x810~60Hz
OpenGL: renderer: Mesa Intel UHD Graphics 620 (KBL GT2) v: 4.6 Mesa 21.2.6
Device-1: Intel Sunrise Point-LP HD Audio vendor: Xiaomi
Sound Server: ALSA v: k5.4.0-121-generic
Device-1: Intel Wireless 8265 / 8275 driver: iwlwifi v: kernel port: 3000
bus ID: 02:00.0
Local Storage: total: 296.89 GiB used: 12.96 GiB (4.4%)
ID-1: /dev/nvme0n1 vendor: Samsung model: MZVLB256HAHQ-00000
ID-2: /dev/sda type: USB vendor: SanDisk model: Cruzer Blade
ID-1: / size: 233.24 GiB used: 12.95 GiB (5.6%) fs: ext4
dev: /dev/nvme0n1p2
System Temperatures: cpu: 52.0 C mobo: 38.0 C
Processes: 276 Uptime: 21m Memory: 7.68 GiB used: 2.20 GiB (28.6%)
Init: systemd runlevel: 5 Compilers: gcc: 9.4.0 Shell: bash v: 5.0.17
inxi: 3.0.38
хотел установить программу, а она выдает вот такую вот ошибку
решил установить через командную строку более свежую версию, но она выдает что уже и так стоит самая новая 2.31
куда копать? как исправить? програма ооочень нужна :cray2:
Решение rogoznik » 26 июн 2022, 18:59
z6785, тут у тебя 2 варианта:
1. Взять версию программы для ubuntu 20.04(именно на ней основан mint 20.x)
2. Поставить ubuntu 22.04, там версию либы как раз 2.34. Mint 21 на основе ubuntu 22.04 хз когда появится, еще даже альфа-версии нет.
Есть конечно, еще третий вариант Обновление LinuxMint-20.3-Una до LinuxMint-21-Vanessa, но это на свой страх и риск
Сообщение rogoznik » 26 июн 2022, 18:32
z6785, что за программа?
z6785
Сообщение z6785 » 26 июн 2022, 18:52
rogoznik, purr data
z6785
Сообщение z6785 » 26 июн 2022, 18:55
rogoznik, попробовал через терминал поставить и тут уже целый букет ошибок
Некоторые пакеты не могут быть установлены. Возможно, то, что вы просите,
неосуществимо, или же вы используете нестабильную версию дистрибутива, где
запрошенные вами пакеты ещё не созданы или были удалены из Incoming.
Следующая информация, возможно, вам поможет:
Следующие пакеты имеют неудовлетворённые зависимости:
purr-data : Зависит: libc6 (>= 2.34) но 2.31-0ubuntu9.9 должен быть установлен
Зависит: libgdk-pixbuf-2.0-0 (>= 2.22.0) но он не может быть установлен
Зависит: libstdc++6 (>= 11) но 10.3.0-1ubuntu1~20.04 должен быть установлен
Зависит: libx11-xcb1 (>= 2:1.7.5) но 2:1.6.9-2ubuntu1.2 должен быть установлен
Рекомендует: tap-plugins но он не будет установлен
Рекомендует: ladspa-foo-plugins но он не будет установлен
Рекомендует: invada-studio-plugins-ladspa но он не будет установлен
Рекомендует: blepvco но он не будет установлен
Рекомендует: swh-plugins но он не будет установлен
Рекомендует: mcp-plugins но он не будет установлен
Рекомендует: cmt но он не будет установлен
Рекомендует: blop но он не будет установлен
Рекомендует: omins но он не будет установлен
Рекомендует: ubuntustudio-audio-plugins но он не будет установлен
Рекомендует: rev-plugins но он не будет установлен
Рекомендует: dssi-utils но он не будет установлен
Рекомендует: vco-plugins но он не будет установлен
Рекомендует: wah-plugins но он не будет установлен
Рекомендует: fil-plugins но он не будет установлен
Рекомендует: mda-lv2 но он не будет установлен
E: Невозможно исправить ошибки: у вас зафиксированы сломанные пакеты.
Сообщение rogoznik » 26 июн 2022, 18:59
Белый Кролик
Решено: 10
Благодарил (а): 354 раза
Сообщение Белый Кролик » 26 июн 2022, 22:40
Чего мучиться когда можно:
flatpak install flathub net.purrdata.PurrData
