Не запускается программа с помощью Wine.
Модератор: WWolf
_Pokoi_
Решено: 6
Благодарил (а): 9 раз
14 июн 2022, 21:26
Kernel: 5.17.14-xanmod1 x86_64 bits: 64 compiler: N/A Desktop: Xfce 4.16.0
Distro: Linux Mint 20.3 Una base: Ubuntu 20.04 focal
Type: Desktop System: Intel product: X79 v: N/A serial: <filter>
Mobo: Intel model: X79Turbo v: V1.x serial: <filter>
UEFI: American Megatrends v: X79QN003 date: 05/28/2021
Topology: 8-Core model: Intel Xeon E5-2689 0 bits: 64 type: MT MCP
arch: Sandy Bridge rev: 7 L2 cache: 20.0 MiB
flags: avx lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 83008
Speed: 1402 MHz min/max: 1200/2601 MHz Core speeds (MHz): 1: 1402 2: 1566
3: 1899 4: 1543 5: 1992 6: 1538 7: 1513 8: 1538 9: 1521 10: 2068 11: 1373
12: 2242 13: 1329 14: 1553 15: 2512 16: 1549
Device-1: AMD Lexa PRO [Radeon 540/540X/550/550X / RX 540X/550/550X]
driver: amdgpu v: kernel bus ID: 03:00.0
Display: x11 server: X.Org 1.20.13 driver: amdgpu,ati
unloaded: fbdev,modesetting,vesa tty: N/A
OpenGL: renderer: AMD Radeon RX 550 / 550 Series (polaris12 LLVM 12.0.0
DRM 3.44 5.17.14-xanmod1)
v: 4.6 Mesa 22.1.1 direct render: Yes
Device-2: AMD Baffin HDMI/DP Audio [Radeon RX 550 640SP / RX 560/560X]
driver: snd_hda_intel v: kernel bus ID: 03:00.1
Sound Server: ALSA v: k5.17.14-xanmod1
Device-1: Realtek RTL810xE PCI Express Fast Ethernet driver: r8169
v: kernel port: d000 bus ID: 07:00.0
IF: enp7s0 state: up speed: 100 Mbps duplex: full mac: <filter>
Local Storage: total: 711.51 GiB used: 96.09 GiB (13.5%)
ID-1: /dev/sda vendor: Samsung model: P3-256 size: 238.47 GiB
ID-2: /dev/sdb type: USB model: 058f 6387 size: 7.28 GiB
ID-3: /dev/sdc type: USB vendor: Seagate model: ST9500424AS
ID-1: / size: 233.18 GiB used: 85.68 GiB (36.7%) fs: ext4 dev: /dev/sda2
System Temperatures: cpu: 32.0 C mobo: N/A gpu: amdgpu temp: 37 C
Fan Speeds (RPM): N/A gpu: amdgpu fan: 1751
Processes: 379 Uptime: 2h 27m Memory: 15.55 GiB used: 4.74 GiB (30.5%)
Init: systemd runlevel: 5 Compilers: gcc: 9.4.0 Shell: bash v: 5.0.17
inxi: 3.0.38
Скачал с оф. сайта ПО для своей клавиатуры https://www.bloody.com/ru/product.php?pid=11&id=241
Установил WIne по инструкции с этого сайта https://any-key.net/wine-linux-mint-20/
Установка программы прошла успешно, запускаю программу,ничего не происходит, запускаю повторно выходит следующее окно (скрин 2):
+ в диспетчере задач отображается как запущенная
wine --version
wine-7.0
Мб есть какое либо альтернативное по а-ля Piper'a для клавиатур ? Гуглил , ничего подобного для клав не нашел .
Почему интерфейс программы не отображается ?
Как сделать чтоб отображался ?
Белый Кролик
Решено: 10
Благодарил (а): 354 раза
14 июн 2022, 22:36
А какую функцию выплняет это ПО для твоей клавиатуры?
14 июн 2022, 23:49
_Pokoi_ писал(а):
14 июн 2022, 21:26
Wine не является волшебной палочкой. Как говорит автор этой публикации, "Заблуждение заключается в том что люди думают что у них получиться запустить из под Wine различный софт, к которому они привыкли и им удобно в нем работать. Как не крути просто так ничего не бывает. ...нужно попотеть, перечитать кучу руководств и взвесить этот объём информации". Какую-то часть информации можно было бы получить, если бы это ПО было запущено в Wine через терминал, который оотобразит вывод что происходит.
_Pokoi_
Решено: 6
15 июн 2022, 18:18
Белый Кролик писал(а):
14 июн 2022, 22:36
Думаю что регулировка яркости и цвета но думаю там должна быть регулировка частоты опроса , хочу убедиться что точно 1000 гц
15 июн 2022, 18:33
_Pokoi_ писал(а):
15 июн 2022, 18:18
хочу убедиться
Если на один раз, то можно кратковременно установить виртуальную машину Windows и проверить. Такой вариант не прокатит?
15 июн 2022, 18:36
_Pokoi_ писал(а):
14 июн 2022, 21:26
видимо так криворуко написано что без обнаружения девайса ничего не рисует
а обнаружить он его не сможет, потому что поддержка usb в вайн реализована только для игровых устройств и не всех..
15 июн 2022, 18:54
_Pokoi_, короче рисует интерфейс видимо через одно место, потому что вываливает ошибки
0138:fixme:uxtheme:DrawThemeTextEx unsupported flags 0x00002a01
можно попробовать через протон запустить, может там взлетит
15 июн 2022, 20:26
15 июн 2022, 18:54
Попробовал через portproton - не отрисовывает. Валит ошибку "Неверный дескриптор окна"
15 июн 2022, 20:46
rogoznik, а для этого можно попробовать врубить виртуальный рабочий стол
15 июн 2022, 21:29
_Pokoi_ писал(а):
15 июн 2022, 18:18
Если это делается для доступа к драйверу устройства (т.е. к железу через драйвер), то Wine идет лесом. Она не предоставляет эмуляцию драйверов, только WinAPI причем довольно высокого уровня. Доступа к железу у нее нет вообще.
madesta писал(а):
15 июн 2022, 18:33
Не прокатит. Только если полным пробросом USB устройства, но в случае клавиатуры - сначала нужно подключить еще одну. А то можно без управления хостом остаться.
15 июн 2022, 18:54
А смысл? Ну отрисует оно интерфейс, возможно, и что дальше? Это ж тот же Wine, доступа к устройствам нету.
Если нету полной поддержки устройства в линуксе, родным драйвером, то никакой виндовый софт здесь не поможет. Только смирится.
15 июн 2022, 21:43
slant, смысл в том, что если она как hid устройство, то обмен вполне может случится, если стандартные api используют для конфигурации...
Но там явно извращенцы, раз даже окно программы через opengl рисуют...
Но попытка не пытка ;-)
_Pokoi_
Решено: 6
16 июн 2022, 01:37
madesta писал(а):
15 июн 2022, 18:33
_Pokoi_ писал(а):
15 июн 2022, 18:18
хочу убедиться
Ни разу не устанавливал виртуальную машину , но в будущем думаю потещу, спасибо за совет
_Pokoi_
Решено: 6
16 июн 2022, 01:42
madesta писал(а):
14 июн 2022, 23:49
Не знаю правильно ли я сделал, но вот что получилось.
wine KeyDominator2.desktop
Приложение не может быть запущено или нет ассоциированных с типом данного докуме
нта приложений.
Вызов ShellExecuteEx провалился: Файл не найден.
wine KeyDominator2.exe
нта приложений.
МОжет неправильное имя файла указал , или как-то по-другому нужно было вписать?
16 июн 2022, 15:32
_Pokoi_ писал(а):
16 июн 2022, 01:42
Мне думается, что должен быть указан полный путь к файлу KeyDominator2.exe, а не просто wine KeyDominator2.exe Включите в менеджере файлов "скрытые файлы", зайдите в папку .wine и посмотрите по какому пути у вас будет ваш exe
_Pokoi_
Решено: 6
16 июн 2022, 19:32
madesta писал(а):
16 июн 2022, 15:32
_Pokoi_ писал(а):
16 июн 2022, 01:42
Ну в общем вот такая ошибка выходит вот так:
wine /home/ui/.wine/drive_c/Program Files (x86)/KeyDominator2/KeyDominator2/KeyDominator2.exe
bash: синтаксическая ошибка рядом с неожиданным маркером «(»
Пробовал стереь пробел между "Program Files" и "(x86)" , удалять скобки , все равно не запускается , пишет, что нет такого файла, выбрать папку установки во время установки нет возможности .
16 июн 2022, 20:42
_Pokoi_, т.к. там пробел необходимо весь путь в кавычки обернуть
_Pokoi_
Решено: 6
16 июн 2022, 23:23
madesta писал(а):
16 июн 2022, 15:32
_Pokoi_ писал(а):
16 июн 2022, 01:42
wine "/home/ui/.wine/drive_c/Program Files (x86)/KeyDominator2/KeyDominator2/KeyDominator2.exe"
0024:fixme:thread:GetThreadUILanguage : stub, returning default language.
0024:fixme:nls:RtlGetThreadPreferredUILanguages 00000038, 0032D9CC, 00000000 0032D9F4
0024:fixme:nls:get_dummy_preferred_ui_language (0x38 0032D9CC 00000000 0032D9F4) returning a dummy value (current locale)
0024:fixme:nls:RtlGetThreadPreferredUILanguages 00000038, 0032D9CC, 03C4C650 0032D9F4
0024:fixme:nls:get_dummy_preferred_ui_language (0x38 0032D9CC 03C4C650 0032D9F4) returning a dummy value (current locale)
0024:fixme:wtsapi:WTSRegisterSessionNotification Stub 00010078 0x00000000
0024:fixme:uxtheme:BufferedPaintInit Stub ()
0024:fixme:wtsapi:WTSRegisterSessionNotification Stub 0001008A 0x00000000
17 июн 2022, 02:06
Если судить по информации с https://appdb.winehq.org, то сведений о запусках вашего ПО в wine не имеется. Соответственно, сайт wineHQ вам не поможет (если не вступить в переписку с разработчиками wine). Я бы учёл мнение slant. Можно, конечно, по каждой из приведенных вами ошибок гуглить, пытаясь найти способы их устранения, но, ИМХО ... :sad:
_Pokoi_
Решено: 6
17 июн 2022, 02:59
madesta писал(а):
17 июн 2022, 02:06
Пожалуй напишу
17 июн 2022, 06:33
_Pokoi_ писал(а):
15 июн 2022, 18:18
Спросить у lsusb.
lsusb -vd [ven_id:dev_id] | grep bInterval
Вернуться в «Wine»
