На втором мониторе черный экран и курсор [не дубль темы]
Grenky
03 мар 2022, 02:59
Итак немного технической информации:
1. обновился с 20.2 до 20.3 cinnamon 64
2. карта GTX 550 TI (драйвер 390.144-0ubuntu0.20.04.1)
System: Kernel: 5.4.0-100-generic x86_64 bits: 64 compiler: gcc v: 9.3.0 Desktop: Cinnamon 5.2.7
Distro: Linux Mint 20.3 Una base: Ubuntu 20.04 focal
Machine: Type: Desktop Mobo: Gigabyte model: Z87P-D3 v: x.x serial: <filter> UEFI: American Megatrends v: F2
date: 04/29/2013
CPU: Topology: Quad Core model: Intel Core i5-4670K bits: 64 type: MCP arch: Haswell rev: 3 L2 cache: 6144 KiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 27137
Speed: 920 MHz min/max: 800/3800 MHz Core speeds (MHz): 1: 1531 2: 1346 3: 1706 4: 1593
Graphics: Device-1: Intel Xeon E3-1200 v3/4th Gen Core Processor Integrated Graphics vendor: Gigabyte driver: i915 v: kernel
bus ID: 00:02.0
Device-2: NVIDIA GF116 [GeForce GTX 550 Ti] vendor: Gigabyte driver: nvidia v: 390.144 bus ID: 01:00.0
Display: x11 server: X.Org 1.20.13 driver: nvidia resolution: 1920x1080~60Hz, 1920x1080~60Hz
OpenGL: renderer: GeForce GTX 550 Ti/PCIe/SSE2 v: 4.6.0 NVIDIA 390.144 direct render: Yes
Audio: Device-1: Intel Xeon E3-1200 v3/4th Gen Core Processor HD Audio driver: snd_hda_intel v: kernel bus ID: 00:03.0
Device-2: Intel 8 Series/C220 Series High Definition Audio vendor: Gigabyte driver: snd_hda_intel v: kernel
bus ID: 00:1b.0
Device-3: NVIDIA GF116 High Definition Audio vendor: Gigabyte driver: snd_hda_intel v: kernel bus ID: 01:00.1
Device-4: MACROSILICON USB Video type: USB driver: hid-generic,snd-usb-audio,usbhid,uvcvideo bus ID: 3-4:3
Sound Server: ALSA v: k5.4.0-100-generic
Network: Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Gigabyte driver: r8169 v: kernel
port: d000 bus ID: 03:00.0
Drives: Local Storage: total: 2.39 TiB used: 55.50 GiB (2.3%)
ID-1: /dev/sda model: SSD2SC120GE2DA08B-T size: 111.79 GiB
ID-2: /dev/sdb vendor: Samsung model: SSD 860 PRO 512GB size: 476.94 GiB
ID-3: /dev/sdc vendor: Seagate model: ST2000DM001-1ER164 size: 1.82 TiB
Partition: ID-1: / size: 276.21 GiB used: 55.47 GiB (20.1%) fs: ext4 dev: /dev/sdb5
Sensors: System Temperatures: cpu: 58.0 C mobo: N/A gpu: nvidia temp: 68 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 74%
Info: Processes: 377 Uptime: 8d 19h 29m Memory: 15.52 GiB used: 11.54 GiB (74.3%) Init: systemd runlevel: 5 Compilers:
gcc: 9.3.0 Shell: bash v: 5.0.17 inxi: 3.0.38
После перезагрузки, я вижу на обоих экранах изображение и окно авторизации. После авторизации на одном мониторе есть картинка, на втором черный экран и только курсор. Проблема решается выдергиванием DVI кабеля и втыканием его обратно. (Видимо происходит переинициализация дисплея). И всё можно работать до следующей перезагрузки.
Можно ли как то прописать делать это переиницализацию? Или может есть не костыльное решение проблемы.
Была соседняя тема схожая, но там не было решения и советов.
03 мар 2022, 07:15
Через xrandr, думаю, возможно провернуть
Grenky
03 мар 2022, 08:27
Мой .xsession-errors после перезагрузки и отключения подключения DVI.
Видно что матерится на монитор, но что это означает и как исправлять не хватает скиллов.
dbus-update-activation-environment: setting DBUS_SESSION_BUS_ADDRESS=unix:path=/run/user/1000/bus
dbus-update-activation-environment: setting DISPLAY=:0
dbus-update-activation-environment: setting XAUTHORITY=/home/grenky/.Xauthority
dbus-update-activation-environment: setting GTK_MODULES=gail:atk-bridge
dbus-update-activation-environment: setting QT_ACCESSIBILITY=1
dbus-update-activation-environment: setting SHELL=/bin/bash
dbus-update-activation-environment: setting XDG_CONFIG_DIRS=/etc/xdg/xdg-cinnamon:/etc/xdg
dbus-update-activation-environment: setting XDG_SESSION_PATH=/org/freedesktop/DisplayManager/Session0
dbus-update-activation-environment: setting LANGUAGE=ru
dbus-update-activation-environment: setting MANDATORY_PATH=/usr/share/gconf/cinnamon.mandatory.path
dbus-update-activation-environment: setting DESKTOP_SESSION=cinnamon
dbus-update-activation-environment: setting PWD=/home/grenky
dbus-update-activation-environment: setting XDG_SESSION_DESKTOP=cinnamon
dbus-update-activation-environment: setting LOGNAME=grenky
dbus-update-activation-environment: setting XDG_SESSION_TYPE=x11
dbus-update-activation-environment: setting GPG_AGENT_INFO=/run/user/1000/gnupg/S.gpg-agent:0:1
dbus-update-activation-environment: setting XDG_GREETER_DATA_DIR=/var/lib/lightdm-data/grenky
dbus-update-activation-environment: setting GDM_LANG=ru
dbus-update-activation-environment: setting HOME=/home/grenky
dbus-update-activation-environment: setting IM_CONFIG_PHASE=1
dbus-update-activation-environment: setting LANG=ru_RU.UTF-8
dbus-update-activation-environment: setting XDG_SEAT_PATH=/org/freedesktop/DisplayManager/Seat0
dbus-update-activation-environment: setting XDG_SESSION_CLASS=user
dbus-update-activation-environment: setting DEFAULTS_PATH=/usr/share/gconf/cinnamon.default.path
dbus-update-activation-environment: setting USER=grenky
dbus-update-activation-environment: setting SHLVL=1
dbus-update-activation-environment: setting XDG_RUNTIME_DIR=/run/user/1000
dbus-update-activation-environment: setting GTK3_MODULES=xapp-gtk3-module
dbus-update-activation-environment: setting XDG_DATA_DIRS=/usr/share/cinnamon:/usr/share/gnome:/home/grenky/.local/share/flatpak/exports/share:/var/lib/flatpak/exports/share:/usr/local/share:/usr/share:/var/lib/snapd/desktop
dbus-update-activation-environment: setting PATH=/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games:/snap/bin
dbus-update-activation-environment: setting GDMSESSION=cinnamon
dbus-update-activation-environment: setting _=/usr/bin/dbus-update-activation-environment
** Message: 15:22:20.458: Existing monitor config (/home/grenky/.config/cinnamon-monitors.xml) not found at startup. Looking for legacy configuration (monitors.xml)
[cinnamon-settings-daemon-smartcard] Failed to start: не удалось найти подходящий драйвер смарт-карт
Cjs-Message: 15:22:22.563: Profiler is disabled. Not setting up signals.
Clutter-Message: 15:22:22.602: Sync method: PRESENTATION TIME
cinnamon-session[1716]: WARNING: t+2,54545s: Failed to start app: Unable to start application: Не удалось выполнить процесс-потомок «/opt/xdman/jre/bin/java» (No such file or directory)
cinnamon-session[1716]: WARNING: t+2,54659s: Failed to start app: Unable to start application: Не удалось выполнить процесс-потомок «flameshot» (No such file or directory)
Tracker-Message: 15:22:22.675: Set scheduler policy to SCHED_IDLE
Tracker-Message: 15:22:22.675: Setting priority nice level to 19
Cjs-Message: 15:22:22.848: JS LOG: About to start Cinnamon
Tracker-Message: 15:22:22.900: Set scheduler policy to SCHED_IDLE
Tracker-Message: 15:22:22.900: Setting priority nice level to 19
qt5ct: using qt5ct plugin
Cjs-Message: 15:22:23.014: JS LOG: [LookingGlass/info] Cinnamon.AppSystem.get_default() started in 154 ms
** (nemo-desktop:2062): WARNING **: 15:22:23.032: Current gtk theme is not known to have nemo support (Adapta-Nokto) - checking...
Cjs-Message: 15:22:23.053: JS LOG: [LookingGlass/info] loading user theme: /home/grenky/.themes/Carta/cinnamon/cinnamon.css
Cjs-Message: 15:22:23.100: JS LOG: [LookingGlass/info] added icon directory: /home/grenky/.themes/Carta/cinnamon
kdeconnect.core: Daemon starting
kdeconnect.core: LanLinkProvider started
kdeconnect.core: Daemon started
kdeconnect.core: Broadcasting identity packet
(nm-applet:2074): libnotify-WARNING **: 15:22:23.164: Failed to connect to proxy
(nm-applet:2074): nm-applet-WARNING **: 15:22:23.165: Failed to show notification: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: The name org.freedesktop.Notifications was not provided by any .service files
kdeconnect.core: Could not query capabilities from notifications server
Cjs-Message: 15:22:23.309: JS LOG: [LookingGlass/info] loaded at Thu Mar 03 2022 15:22:23 GMT+1000 (Владивосток, стандартное время)
Cjs-Message: 15:22:23.309: JS LOG: Cinnamon started at Thu Mar 03 2022 15:22:23 GMT+1000 (Владивосток, стандартное время)
Cjs-Message: 15:22:23.326: JS LOG: [LookingGlass/info] ExtensionSystem started in 1 ms
Cjs-Message: 15:22:23.326: JS LOG: [LookingGlass/info] NaNms
Cjs-Message: 15:22:23.326: JS LOG: [LookingGlass/info] SearchProviderManager started in 0 ms
openGL version 3.1 detected (GL3 Cogl Driver)
Cjs-Message: 15:22:23.406: JS LOG: [LookingGlass/info] Loaded applet removable-drives@cinnamon.org in 52 ms
Cjs-Message: 15:22:23.410: JS LOG: [LookingGlass/info] Role locked: tray
Cjs-Message: 15:22:23.414: JS LOG: [LookingGlass/info] Loaded applet systray@cinnamon.org in 8 ms
Cjs-Message: 15:22:23.420: JS LOG: [LookingGlass/info] Loaded applet separator@cinnamon.org in 6 ms
Cjs-Message: 15:22:23.462: JS LOG: [LookingGlass/info] Loaded applet calendar@cinnamon.org in 42 ms
Cjs-Message: 15:22:23.520: JS LOG: [LookingGlass/info] Loaded applet printers@cinnamon.org in 58 ms
St-Message: 15:22:23.531: cogl npot texture sizes SUPPORTED
Cjs-Message: 15:22:23.537: JS LOG: [LookingGlass/info] Role locked: notifications
Cjs-Message: 15:22:23.550: JS LOG: [LookingGlass/info] Loaded applet notifications@cinnamon.org in 30 ms
cinnamon-session[1716]: WARNING: t+3,43884s: Detected that screensaver has appeared on the bus
(tracker-miner-fs:2039): Tracker-CRITICAL **: 15:22:23.589: Could not request DBus name 'org.freedesktop.Tracker1.Miner.Files': D-Bus service name:'org.freedesktop.Tracker1.Miner.Files' is already taken, perhaps the application is already running?
Cjs-Message: 15:22:23.594: JS LOG: [LookingGlass/info] Loaded applet keyboard@cinnamon.org in 44 ms
Cjs-Message: 15:22:23.599: JS LOG: [LookingGlass/info] Loaded applet xapp-status@cinnamon.org in 5 ms
Cjs-Message: 15:22:23.695: JS LOG: [LookingGlass/info] Loaded applet temperature@fevimu in 96 ms
** Message: 15:22:23.757: nemo-desktop: session is cinnamon, establishing proxy
Cjs-Message: 15:22:23.805: JS LOG: [LookingGlass/info] [weather@mockturtl#30]: Internet access now available, resuming operations.
Cjs-Message: 15:22:23.820: JS LOG: [LookingGlass/info] Loaded applet weather@mockturtl in 125 ms
Cjs-Message: 15:22:23.832: JS LOG: [LookingGlass/info] Loaded applet ShutdownMenuWithIcons@LLOBERA in 12 ms
(tracker-extract:2091): Tracker-CRITICAL **: 15:22:23.856: Could not request DBus name 'org.freedesktop.Tracker1.Miner.Extract': D-Bus service name:'org.freedesktop.Tracker1.Miner.Extract' is already taken, perhaps the application is already running?
Cjs-Message: 15:22:23.874: JS LOG: [LookingGlass/info] Role locked: panellauncher
Cjs-Message: 15:22:23.877: JS LOG: [LookingGlass/info] Loaded applet grouped-window-list@cinnamon.org in 44 ms
Cjs-Message: 15:22:23.883: JS LOG: [LookingGlass/info] Adding XAppStatusIcon: nm-applet (:1.61/org/x/StatusIcon/Icon)
Cjs-Message: 15:22:23.919: JS LOG: [LookingGlass/info] Loaded applet sound@cinnamon.org in 42 ms
Cjs-Message: 15:22:23.928: JS LOG: [LookingGlass/info] Loaded applet hideable-applets@cardsurf in 9 ms
Cjs-Message: 15:22:23.974: JS LOG: [LookingGlass/info] Hiding XAppStatusIcon (we have an applet): nm-applet (:1.61/org/x/StatusIcon/Icon)
Cjs-Message: 15:22:23.985: JS LOG: [LookingGlass/info] Loaded applet network@cinnamon.org in 56 ms
Cjs-Message: 15:22:24.154: JS LOG: [LookingGlass/info] Loaded applet menu@cinnamon.org in 169 ms
Cjs-Message: 15:22:24.155: JS LOG: [LookingGlass/info] AppletManager started in 845 ms
Cjs-Message: 15:22:24.158: JS LOG: [LookingGlass/info] Cinnamon took 1309 ms to start
Cjs-Message: 15:22:24.171: JS LOG: Unknown network device type, is 14
(cinnamon:2014): St-WARNING **: 15:22:24.329: Ignoring length property that isn't a number at line 1340, col 13
Cjs-Message: 15:22:24.513: JS LOG: [LookingGlass/info] Adding systray: anydesk (24x24px)
Cjs-Message: 15:22:24.513: JS LOG: [LookingGlass/info] Resized anydesk with normalized size (24x24px)
Cjs-Message: 15:22:24.995: JS LOG: [LookingGlass/info] Adding XAppStatusIcon: nvidia-prime (:1.57/org/x/StatusIcon/Icon)
Cjs-Message: 15:22:26.683: JS LOG: [LookingGlass/info] [weather@mockturtl#30]: Weather Information refreshed
** Message: 15:22:33.618: Existing monitor config (/home/grenky/.config/cinnamon-monitors.xml) not found during hotplug or laptop lid event. Looking for legacy configuration (monitors.xml)
** Message: 15:22:35.864: Existing monitor config (/home/grenky/.config/cinnamon-monitors.xml) not found during hotplug or laptop lid event. Looking for legacy configuration (monitors.xml)
** (csd-color:1886): WARNING **: 15:22:35.869: failed to reset xrandr-Acer Technologies-G246HYL-LZ5EE0082400 gamma tables: gamma size is zero
(cinnamon:2014): Cjs-CRITICAL **: 15:22:36.318: Object St.Icon (0x55c8bd6f03f0), has been already deallocated — impossible to set any property on it. This might be caused by the object having been destroyed from C code using something such as destroy(), dispose(), or remove() vfuncs.
== Stack trace for context 0x55c8bc1d4100 ==
#0 7fff3b8c5f60 b /usr/share/cinnamon/js/ui/osdWindow.js:209 (3b0aa1b38380 @ 219)
#1 7fff3b8c6030 b self-hosted:850 (d84b1dc2920 @ 423)
#2 7fff3b8c6120 b resource:///org/gnome/gjs/modules/core/_signals.js:133 (d84b1dad880 @ 439)
#3 55c8bc664a18 i /usr/share/cinnamon/js/ui/layout.js:155 (3b0aa1b62b50 @ 52)
#4 7fff3b8c6cc0 b self-hosted:850 (d84b1dc2920 @ 423)
(cinnamon:2014): Cjs-CRITICAL **: 15:22:36.318: Object St.BoxLayout (0x55c8bd68ef90), has been already deallocated — impossible to access it. This might be caused by the object having been destroyed from C code using something such as destroy(), dispose(), or remove() vfuncs.
#0 7fff3b8c5f60 b /usr/share/cinnamon/js/ui/osdWindow.js:210 (3b0aa1b38380 @ 259)
(cinnamon:2014): Clutter-CRITICAL **: 15:22:36.319: clutter_actor_set_size: assertion 'CLUTTER_IS_ACTOR (self)' failed
(cinnamon:2014): Cjs-CRITICAL **: 15:22:36.319: Object St.BoxLayout (0x55c8bd68ef90), has been already deallocated — impossible to set any property on it. This might be caused by the object having been destroyed from C code using something such as destroy(), dispose(), or remove() vfuncs.
#0 7fff3b8c5f60 b /usr/share/cinnamon/js/ui/osdWindow.js:211 (3b0aa1b38380 @ 309)
#0 7fff3b8c5f60 b /usr/share/cinnamon/js/ui/osdWindow.js:212 (3b0aa1b38380 @ 359)
(cinnamon:2014): Cjs-CRITICAL **: 15:22:36.440: Object St.Icon (0x55c8bd6f03f0), has been already deallocated — impossible to set any property on it. This might be caused by the object having been destroyed from C code using something such as destroy(), dispose(), or remove() vfuncs.
(cinnamon:2014): Cjs-CRITICAL **: 15:22:36.440: Object St.BoxLayout (0x55c8bd68ef90), has been already deallocated — impossible to access it. This might be caused by the object having been destroyed from C code using something such as destroy(), dispose(), or remove() vfuncs.
(cinnamon:2014): Clutter-CRITICAL **: 15:22:36.440: clutter_actor_set_size: assertion 'CLUTTER_IS_ACTOR (self)' failed
(cinnamon:2014): Cjs-CRITICAL **: 15:22:36.440: Object St.BoxLayout (0x55c8bd68ef90), has been already deallocated — impossible to set any property on it. This might be caused by the object having been destroyed from C code using something such as destroy(), dispose(), or remove() vfuncs.
(cinnamon:2014): Cjs-CRITICAL **: 15:22:36.463: Object St.Icon (0x55c8bd6f03f0), has been already deallocated — impossible to set any property on it. This might be caused by the object having been destroyed from C code using something such as destroy(), dispose(), or remove() vfuncs.
(cinnamon:2014): Cjs-CRITICAL **: 15:22:36.463: Object St.BoxLayout (0x55c8bd68ef90), has been already deallocated — impossible to access it. This might be caused by the object having been destroyed from C code using something such as destroy(), dispose(), or remove() vfuncs.
(cinnamon:2014): Clutter-CRITICAL **: 15:22:36.464: clutter_actor_set_size: assertion 'CLUTTER_IS_ACTOR (self)' failed
(cinnamon:2014): Cjs-CRITICAL **: 15:22:36.464: Object St.BoxLayout (0x55c8bd68ef90), has been already deallocated — impossible to set any property on it. This might be caused by the object having been destroyed from C code using something such as destroy(), dispose(), or remove() vfuncs.
(cinnamon:2014): Cjs-CRITICAL **: 15:22:36.469: Object St.Icon (0x55c8bd6f03f0), has been already deallocated — impossible to set any property on it. This might be caused by the object having been destroyed from C code using something such as destroy(), dispose(), or remove() vfuncs.
(cinnamon:2014): Cjs-CRITICAL **: 15:22:36.469: Object St.BoxLayout (0x55c8bd68ef90), has been already deallocated — impossible to access it. This might be caused by the object having been destroyed from C code using something such as destroy(), dispose(), or remove() vfuncs.
(cinnamon:2014): Clutter-CRITICAL **: 15:22:36.469: clutter_actor_set_size: assertion 'CLUTTER_IS_ACTOR (self)' failed
(cinnamon:2014): Cjs-CRITICAL **: 15:22:36.469: Object St.BoxLayout (0x55c8bd68ef90), has been already deallocated — impossible to set any property on it. This might be caused by the object having been destroyed from C code using something such as destroy(), dispose(), or remove() vfuncs.
Cinnamon warning: Log level 16: Failed to create background texture from pixmap: Unable to query pixmap size
(cinnamon:2014): St-WARNING **: 15:22:41.642: parse_shadow_property: default case
Cjs-Message: 15:22:43.297: JS LOG: [LookingGlass/info] Adding XAppStatusIcon: mintUpdate.py (:1.96/org/x/StatusIcon/Icon)
cinnamon-session[1716]: WARNING: t+33,44312s: Detected that screensaver has left the bus
Cjs-Message: 15:23:08.319: JS LOG: [LookingGlass/info] Adding XAppStatusIcon: mintreport (:1.104/org/x/StatusIcon/Icon)
nikello
10 июл 2022, 11:31
Та же самая проблема. Ноутбук с двумя видеокартами (встроенная Intel и дискретная Nvidia). Подключаю второй монитор через HDMI - на нам отображается только курсор мыши, черный экран и окна туда не переносятся...
Логи: https://linux-hardware.org/?probe=4d0187940b
# xrandr | grep -w connected
eDP-1 connected primary 1920x1080+1920+0 (normal left inverted right x axis y axis) 344mm x 193mm
HDMI-1-1 connected 1920x1080+0+0 (normal left inverted right x axis y axis) 597mm x 336mm
# lspci | grep VGA
00:02.0 VGA compatible controller: Intel Corporation UHD Graphics 630 (Mobile)
01:00.0 VGA compatible controller: NVIDIA Corporation Device 1f95 (rev a1)
Благодарил (а): 1218 раз
10 июл 2022, 11:52
Было как то раз такое. Уже и не помню на каком по номеру LM. в тот раз решил выбором во время загрузки другого ядра, потом после обновлений системы это уже не повторялось
10 июл 2022, 12:40
nikello писал(а):
10 июл 2022, 11:31
Вот в этом возможен корень проблемы. У вашего ноутбука, видимо (не могу открыть ссылку на железо, но симптом характерный), внешний монитор цепляется к второй карте (а не к второму выводу первой). В линуксе такая конфигурация приводит к вышеописанному явлению, т.к. для второй карты с монитором запускается отдельный экземпляр X сервера. В результате получается два практически независимых друг от друга рабочих места, а не общий рабочий стол. Это, к сожалению, больное место графической системы на иксах, и принципиально здесь почти ничего не сделать. Существует расширение иксов Xinerama, но ее задействование рубит DRM вывод (если правильно помню), что в современной системе приводит к печальным последствиям - теряется акселерация графики. Если это оно - то не лечится. :(
Если же два монитора подключаются к одной карте, а вторая работает в тяжелых задачах через Nvidia optimus (вывод изображения в память первой, а не собственный монитор, динамически подключаясь когда надо), как это сделано на подавляющем большинстве таких ноутбуков, то можете вышеописанное пропустить - не ваш случай.
nikello
19 июл 2022, 11:57
Короче в Ubuntu Mate все завелось с полпинка
dkpost3
Благодарил (а): 9 раз
20 июл 2022, 22:16
Grenky писал(а):
03 мар 2022, 02:59
вам сюда https://linuxmint-user-guide.readthedoc ... /edge.html
Вернуться в «Видеокарты»
