Cильные фризы(тормоза) Linux Mint 20.1 x64 Xfce 4.14.2
О том о сем
AntKant
Сообщение AntKant » 21 май 2021, 11:32
Kernel: 5.4.0-73-generic x86_64 bits: 64 compiler: gcc v: 9.3.0
Desktop: Xfce 4.14.2 Distro: Linux Mint 20.1 Ulyssa
base: Ubuntu 20.04 focal
Type: Laptop System: Acer product: Aspire E1-572G v: V2.13
serial: <filter>
Mobo: Acer model: EA50_HW v: V2.13 serial: <filter> UEFI: Insyde v: 2.13
date: 11/21/2013
ID-1: BAT1 charge: 12.8 Wh condition: 12.8/37.0 Wh (35%)
model: SANYO AL12A32 status: Full
Topology: Dual Core model: Intel Core i3-4010U bits: 64 type: MT MCP
arch: Haswell rev: 1 L2 cache: 3072 KiB
bogomips: 13568
Speed: 1696 MHz min/max: 800/1700 MHz Core speeds (MHz): 1: 1696 2: 1696
3: 1696 4: 1696
Device-1: Intel Haswell-ULT Integrated Graphics
Device-2: AMD Jet XT [Radeon R5 M240] vendor: Acer Incorporated ALI
driver: radeon v: kernel bus ID: 02:00.0
Display: x11 server: X.Org 1.20.9 driver: ati,modesetting,radeon
unloaded: fbdev,vesa resolution: 1366x768~60Hz
OpenGL: renderer: Mesa DRI Intel HD Graphics 4400 (HSW GT2)
v: 4.5 Mesa 20.2.6 direct render: Yes
Device-1: Intel Haswell-ULT HD Audio vendor: Acer Incorporated ALI
driver: snd_hda_intel v: kernel bus ID: 00:03.0
Device-2: Intel 8 Series HD Audio vendor: Acer Incorporated ALI
Sound Server: ALSA v: k5.4.0-73-generic
Device-1: Broadcom and subsidiaries NetXtreme BCM57786 Gigabit Ethernet
PCIe
vendor: Acer Incorporated ALI driver: tg3 v: 3.137 port: 4040
bus ID: 01:00.0
IF: enp1s0f0 state: down mac: <filter>
Device-2: Realtek RTL8192CU 802.11n WLAN Adapter type: USB
driver: rtl8192cu bus ID: 2-1:2
IF: wlxd46e0e0eb2c1 state: up mac: <filter>
Local Storage: total: 223.58 GiB used: 19.62 GiB (8.8%)
ID-1: /dev/sda vendor: SanDisk model: SDSSDHII120G size: 111.79 GiB
ID-2: /dev/sdb vendor: Kingston model: SA400S37120G size: 111.79 GiB
ID-1: / size: 29.23 GiB used: 19.59 GiB (67.0%) fs: ext4 dev: /dev/sda3
System Temperatures: cpu: 47.0 C mobo: N/A gpu: radeon temp: 45 C
Processes: 178 Uptime: 35m Memory: 7.66 GiB used: 2.03 GiB (26.5%)
inxi: 3.0.38
1) Внешний модуль типа "свисток" Wifi TP-link WN821N после установки работал нормально несколько дней. Сейчас в лучшем случае дает 1М/б в секунду. В виндоус это же оборудование работает исправно. Точки отката TimeShift нет. Как вернуть в рабочее состояние ?
2) В Минт и Убунту свисток постоянно включен - горит световой индикатор и греется. А в виндоус мигает только при передаче данных. Это нормально ?
ilikethat
Решено: 10
Благодарил (а): 128 раз
Сообщение ilikethat » 21 май 2021, 13:01
Пару дней назал, вытащил старый ноут, чтобы зарядить.
На нем стоят две копии минт 20, с Cinnamon и XFCE.
Загрузиля в XFCE. Через несколько минут обратил внимание, что ноут стал выть ветиляторами.
В общем процесс xorg отжирал одно ядро из двух. Суммарная загрузка 60-65% на рабочем столе.
Перегрузился в Cinnamon, там все ок, 5-15%
ХЗ чего это было, но снес систему с XFCE.
AntKant
Сообщение AntKant » 21 май 2021, 13:47
ilikethat писал(а):
21 май 2021, 13:01
Складывается впечатление, что линуксы как были в 90-е годы не стабильными системами так и остались. И даже надежды на развитие уже нет...
Сообщение rogoznik » 21 май 2021, 13:53
AntKant писал(а):
21 май 2021, 11:32
Складывается впечатление, что кто-то что-то не договаривает. Не бывает ничего "само".
Решено: 37
Сообщение WWolf » 21 май 2021, 13:54
AntKant, винда капец стабильна :-D
AntKant
Сообщение AntKant » 21 май 2021, 13:58
21 май 2021, 13:54
Win 98 падала по 2-а раза в день. XP раз в пол года. Начиная с 7-ки - даже разговоров о стабильности нет. А вот любое видео по обзору линуксов включи - постоянно речь о том какая версия стабильнее.
sheridan
Решено: 14
Благодарил (а): 900 раз
Сообщение sheridan » 21 май 2021, 14:22
AntKant писал(а):
21 май 2021, 13:58
21 май 2021, 13:54
С таким настроением как у Вас необходимо назад к окнам, линукс не любит суеты, любит терпение, винда для кухарок и домохозяек , которым совершенно не интересно как все устроено, либо для геймеров.
AntKant
Сообщение AntKant » 21 май 2021, 14:27
sheridan писал(а):
21 май 2021, 14:22
Мне работать надо. А тут выбор изучать линукс или дела делать.
Сообщение slant » 21 май 2021, 14:47
AntKant писал(а):
21 май 2021, 13:47
Провожу аналогию с автомобилями:
Винда - это мерседес, городской автомобиль где водителю запрещается лезть куда угодно, и под капот тоже. Ездить по дороге, в случае чего - сразу в сервис.
Линукс - это основа армейского джипа на которую ставится кузов в зависимости от требуемых задач. В который можно залезть по уши. Который может пройти по любому болоту, т.к. даже гусеницы, водонепроницаемый корпус, и водомет прикутить можно. Можно также и снять все лишнее получив спортивную багги. Или поставить сверху аэродинамику и получить "формулу". Но по умолчанию - это все равно джип. Ест побольше, скорость поменьше, и т.д. А заточка под задачу требует некоторого усилия и ручной работы. Зато можно обслуживать самостоятельно. И документация есть, ничего от вас не прячут, что хотите то с ним и делайте.
Какой подход лучше? А нету такого. Кому что ближе. Ездить по дороге на работу в офис и в магазин по воскресеньям - джип не нужен... А в путешествия, да на отдых на природу - мерседес там и застрять с концами может. :)
Что касается развития: а что есть развитие для машины? Повышение проходимости? Рост максимальной скорости? Количество сервисов на город? Меньшие затраты топлива на километр? Так оно тоже друг другу противоречит, если смотреть чуть дальше своего носа. Надо выбирать то, что нужно лично вам.
Бессмысленно линукс и винду сравнивать абстрактно "что лучше". Только в контексте применения.
Но одно я могу сказать точно: если система "нестабильна" - 95% причины в этом из-за железа и оператора с которые этой системой пользуются. Это касается сейчас как винды так и линуксов. И не надо аргументов: "по виндой оно работает". Через меня прошло куча глючного железа которое "под линуксом оно работает". Эти два множества лишь частично пересекаются.
AntKant
Сообщение AntKant » 21 май 2021, 15:07
Собрать автомобиль может каждый. Но он не будет хорошим. Линукс это как большой склад запчастей хороших и плохих, маленьких и больших. Единого центра кто б указывал используйте это потому что..., и не берите это потому что..., нет. В итоге - выкатывают каждый год 10 линухов , которые представляют из себя"винегрет" из случайных компонентов. Совсем не учитывают, то что раньше сделано хорошо или плохо.
Даже по дизайну - поставил Убунту "Бегемот". Дизайн вырви глаз. Блогер с ютуба сказал, что лучше способ привить отвращение к линуху навсегда - поставить Бегемота на гноме. В МакОС есть единый стандарт качества и Винде есть. А линукс безнадежен. Нет стандарта того, что называют "хорошим, удачным".
Решено: 37
Сообщение WWolf » 21 май 2021, 15:11
AntKant, ну так и сиди на квадратной десятке с дизайном окон из 3.11 и не лезь на линукс :) тебя ж никто не заставляет, но ты лезешь, ломаешь, не разбираешься и дальше хаешь... как сказал бы Гоблин - малолетний дебил..
Whowka
Благодарил (а): 777 раз
Сообщение Whowka » 21 май 2021, 15:14
Вайфай свисток уже никому не интересен? Или тему переименовать и в "Болталку"? :tema:
AntKant
Сообщение AntKant » 21 май 2021, 15:17
21 май 2021, 15:11
По необходимости поставил линукс. А зачем я должен разбираться ? Ведь компьютер не для линукса, а для работы и развлечений.
А вот оскарбления и возраст характеризуют тебя.
Решено: 37
Сообщение WWolf » 21 май 2021, 15:18
AntKant писал(а):
21 май 2021, 15:17
:crazy:
Сообщение slant » 21 май 2021, 15:51
AntKant писал(а):
21 май 2021, 15:17
Не хотите разбираться - вам на винду. Линукс - инструмент. Которым нужно уметь работать, иметь знания. Если вы не хотите уметь и знать - вам не сюда. Очень просто.
Если, скажем, вы электролобзик купите - и по незнанию ТБ и приемов работы себе палец отрежете - тоже будет говорить что лобзик виноват? Что "мне работать надо а не разбираться?"
AntKant
Сообщение AntKant » 21 май 2021, 15:55
С лобзиком разобраться не трудно. А если, что посложнее - для этого есть специалисты. А изучать линукс ради линукса это как хобби собирать модели самолетиков. Вещь в себе. Просто не надо морочить голову людям и популяризировать ОС. Честно признаться, что это хобби. Работать на ней нельзя.
Решено: 37
Сообщение WWolf » 21 май 2021, 16:04
AntKant писал(а):
21 май 2021, 15:55
ааааааа :cray2: скажи это всем суперкомпьютерам в мире и 80% серверам в интернете, а то они не знают. Без тебя никак бы не додумались что надо как-то винду туда корячить
Сообщение slant » 21 май 2021, 16:19
21 май 2021, 16:04
ааааааа скажи это всем суперкомпьютерам в мире и 80% серверам в интернете, а то они не знают. Без тебя никак бы не додумались что надо как-то винду туда корячить
Ага, а еще аниматорам pixar (и не им одним, но именно они первыми явно написал на чем работают и почему), как минимум процентам 20-30 музыкальных групп и студий, множеству диайзнеров и аниматоров использующих blender в качестве инструмента (и нет, далеко не все используют виндовс версию). Опять же - в телефонах и телевизорах, маршутизаторах и прочей домашней электронике сейчас что? Оно самое. Специализированное, но именно оно. За исключением тех что у эппла, но и там ноги растут из BSD, что тоже довольно близко. :)
AntKant писал(а):
21 май 2021, 15:55
Лично вас - никто не заставляет. Но если люди выбирают ОС на базе Linux - значит вполне можно, и кому-то нужно. В чужой монастырь со своим уставом не ходят. Не стоит указывать кому что делать, и вам тоже направления движения диктовать не будут. :)
AntKant
Сообщение AntKant » 21 май 2021, 16:40
21 май 2021, 16:19
Вот именно. Уникс системы хороши для одной задачи. Исключение андроид и МакОС. У них один хозяин и собирают по принципу удобно и стабильно. А линукс - мертв. Тупиковая ветвь развития. Каждый раз получается глючный "винегрет". Как в песне - "Я его собрала из того, что было. А потом что было то и полюбила..."
Сообщение rogoznik » 21 май 2021, 16:45
AntKant писал(а):
21 май 2021, 15:55
Странно, а я работаю. И на всех домашних компах стоит линукс и проблем нет. ЧЯДНТ?
