Не работает тачпад Linux Mint 18.1 Cinnamon
bonishvarik
24 фев 2017, 10:33
Все привет! Прошу помощи.
Установил на ноутбук Fijutsu UH552 Linux Mint 18.1 Cinnamon.
Все настроил, а тачпад не поднимается. Вообще никак и ни на что не реагирует.
Для информации:
LIFEBOOK-UH552 user # dmesg | tail
[ 52.051273] psmouse serio1: bad data from KBC - timeout
[ 52.053307] psmouse serio1: bad data from KBC - timeout
[ 52.055342] psmouse serio1: bad data from KBC - timeout
[ 52.057225] psmouse serio1: bad data from KBC - timeout
[ 52.060292] psmouse serio1: bad data from KBC - timeout
[ 52.062173] psmouse serio1: bad data from KBC - timeout
[ 52.064303] psmouse serio1: bad data from KBC - timeout
[ 52.066185] psmouse serio1: bad data from KBC - timeout
[ 52.068308] psmouse serio1: bad data from KBC - timeout
[ 52.070258] psmouse serio1: bad data from KBC - timeout
LIFEBOOK-UH552 user # xinput --list | grep TouchPad
⎜ ↳ SynPS/2 Synaptics TouchPad id=14 [slave pointer (2)]
xserver-xorg-input-synaptics установлен
LIFEBOOK-UH552 user # xinput list-props "SynPS/2 Synaptics TouchPad" (файл добавлял вручную)
Device 'SynPS/2 Synaptics TouchPad':
Device Enabled (138): 1
Coordinate Transformation Matrix (140): 1.000000, 0.000000, 0.000000, 0.000000, 1.000000, 0.000000, 0.000000, 0.000000, 1.000000
Device Accel Profile (270): 1
Device Accel Constant Deceleration (271): 1.000000
Device Accel Adaptive Deceleration (272): 1.000000
Device Accel Velocity Scaling (273): 12.500000
Synaptics Edges (295): 1752, 5192, 1620, 4236
Synaptics Finger (296): 25, 30, 0
Synaptics Tap Time (297): 180
Synaptics Tap Move (298): 221
Synaptics Tap Durations (299): 180, 100, 100
Synaptics ClickPad (300): 1
Synaptics Middle Button Timeout (301): 0
Synaptics Two-Finger Pressure (302): 282
Synaptics Two-Finger Width (303): 7
Synaptics Scrolling Distance (304): -100, -100
Synaptics Edge Scrolling (305): 1, 0, 0
Synaptics Two-Finger Scrolling (306): 1, 0
Synaptics Move Speed (307): 1.000000, 1.750000, 0.102881, 0.000000
Synaptics Off (308): 2
Synaptics Locked Drags (309): 1
Synaptics Locked Drags Timeout (310): 5000
Synaptics Tap Action (311): 0, 0, 8, 0, 0, 0, 0
Synaptics Click Action (312): 1, 3, 2
Synaptics Circular Scrolling (313): 0
Synaptics Circular Scrolling Distance (314): 0.100000
Synaptics Circular Scrolling Trigger (315): 0
Synaptics Circular Pad (316): 0
Synaptics Palm Detection (317): 1
Synaptics Palm Dimensions (318): 4, 1
Synaptics Coasting Speed (319): 20.000000, 50.000000
Synaptics Pressure Motion (320): 30, 160
Synaptics Pressure Motion Factor (321): 1.000000, 1.000000
Synaptics Resolution Detect (322): 1
Synaptics Grab Event Device (323): 0
Synaptics Gestures (324): 1
Synaptics Capabilities (325): 1, 0, 0, 1, 1, 1, 1
Synaptics Pad Resolution (326): 73, 55
Synaptics Area (327): 0, 0, 0, 0
Synaptics Soft Button Areas (328): 0, 1629, 1737, 0, 1630, 0, 1737, 0
Synaptics Noise Cancellation (329): 8, 8
Device Product ID (259): 2, 7
Device Node (260): "/dev/input/event6"
Горячие клавиши включения тачпада не помогают. Вообще не реагирует на нажатие Fn+F4, остальные комбинации (громкость, яркость) работают. В LiveCD тачпад не работает, на винде не проверял, изначально стоял линукс (и на старом лине не работал).
В графическом режие в настройках тачпад определяется наравне с мышью и даже показывает, как включенный.
Сталкивался ли кто-нибудь с подобным?
Решение rut » 19 апр 2018, 20:44
Unborn, Вообщем решение найдено Взлетело мгновенно. Надо фиксить Груб.
Extend the line with adding the above mentioned kernel boot parameter like below.
GRUB_CMDLINE_LINUX_DEFAULT="quiet splash i8042.notimeout i8042.nomux"
Then update the rub
sudo update-grub
Reeboot the system,
25 фев 2017, 19:25
может быть немного не в тему... но 1 - если изначально стоял линь и на этом изначальном варианте тач не работал... то может быть дело в самом таче? (как его вообще взяли то при не рабочем).
2 - маленькая мышь с хвостиком USB удобней тачпада. (я тачпадом пользуюсь только когда мышью неудобно, но такие моменты очень редки).
abulaev2008
Благодарил (а): 24 раза
17 дек 2017, 14:44
Аналогичная проблема, Минт, Мате не видит тач. Ноутбук Леново 320 купил новый с DOS. даже не определяется системой. Как быть
17 дек 2017, 16:29
abulaev2008 писал(а):
17 дек 2017, 14:44
17 дек 2017, 14:44
Как быть
Для начала создать новую тему, а перед созданием почитать что написано в красном поле вверху страницы и подготовить всю необходимую информацию
abulaev2008
17 дек 2017, 17:30
Этой темы достаточно. Проблема: Линукс не определяет тач. Xinput также не выводит это железо. Как быть? только не надо про СЦ
abulaev2008
17 дек 2017, 17:36
нет в линукс
[andrey@andrey-Lenovo ~ $ xinput -list
⎡ Virtual core pointer id=2 [master pointer (3)]
⎜ ↳ Virtual core XTEST pointer id=4 [slave pointer (2)]
⎜ ↳ Telink 2.4G Mouse id=8 [slave pointer (2)]
⎣ Virtual core keyboard id=3 [master keyboard (2)]
↳ Virtual core XTEST keyboard id=5 [slave keyboard (3)]
↳ Video Bus id=6 [slave keyboard (3)]
↳ Power Button id=7 [slave keyboard (3)]
↳ EasyCamera id=9 [slave keyboard (3)]
↳ Ideapad extra buttons id=10 [slave keyboard (3)]
↳ AT Translated Set 2 keyboard id=11 [slave keyboard (3)]
andrey@andrey-Lenovo ~ $ ^C
/spoil]
при том, что он есть
17 дек 2017, 18:01
17 дек 2017, 16:29
Т.е. это делать не собираешься?
17 дек 2017, 18:03
abulaev2008, Asus N551JM & K50AB. Режимы: сон и ждущий для сравнения с вашей жалкой информацией.
а по сабжу я уже писал - лучше мыши может быть только другая мышь :crazy:
17 дек 2017, 18:11
Похоже, что аппаратно отключен тач.
cat /proc/bus/input/devices
есть хоть намёк на него?
17 дек 2017, 14:44
Может в УЕФИ отключен. Зачем в ДОС тачпад.
abulaev2008
17 дек 2017, 19:06
В Bios не упоминается, горячие кнопки все работают кроме Fn+F6(вкл.выкл) Тача, Пробовал Ubuntu 16.04, Mate, сейчас Минт 18. Пробовал загрузится с Vistы. Тач не работает. После рытья в Инете повесил систему, так что пропала и клава (не мог ввести пароль)
andrey@andrey-Lenovo ~ $ cat /proc/bus/input/devices
I: Bus=0019 Vendor=0000 Product=0005 Version=0000
N: Name="Lid Switch"
P: Phys=PNP0C0D/button/input0
S: Sysfs=/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0D:00/input/input0
U: Uniq=
H: Handlers=event0
B: PROP=0
B: EV=21
B: SW=1
I: Bus=0019 Vendor=0000 Product=0001 Version=0000
N: Name="Power Button"
P: Phys=PNP0C0C/button/input0
S: Sysfs=/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input1
U: Uniq=
H: Handlers=kbd event1
B: PROP=0
B: EV=3
B: KEY=10000000000000 0
I: Bus=0011 Vendor=0001 Product=0001 Version=ab83
N: Name="AT Translated Set 2 keyboard"
P: Phys=isa0060/serio0/input0
S: Sysfs=/devices/platform/i8042/serio0/input/input2
U: Uniq=
H: Handlers=sysrq kbd event2 leds
B: PROP=0
B: EV=120013
B: KEY=402000000 3803078f800d001 feffffdfffefffff fffffffffffffffe
B: MSC=10
B: LED=7
I: Bus=0019 Vendor=0000 Product=0006 Version=0000
N: Name="Video Bus"
P: Phys=LNXVIDEO/video/input0
S: Sysfs=/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:00/input/input3
U: Uniq=
H: Handlers=kbd event3
B: PROP=0
B: EV=3
B: KEY=3e000b00000000 0 0 0
I: Bus=0019 Vendor=0000 Product=0000 Version=0000
N: Name="Ideapad extra buttons"
P: Phys=ideapad/input0
S: Sysfs=/devices/pci0000:00/0000:00:1f.0/PNP0C09:00/VPC2004:00/input/input5
U: Uniq=
H: Handlers=rfkill kbd event5
B: PROP=0
B: EV=13
B: KEY=101400800100c03 400000000300000 0 2
B: MSC=10
I: Bus=0000 Vendor=0000 Product=0000 Version=0000
N: Name="HDA Intel PCH Mic"
P: Phys=ALSA
S: Sysfs=/devices/pci0000:00/0000:00:0e.0/sound/card0/input6
U: Uniq=
H: Handlers=event6
B: PROP=0
B: EV=21
B: SW=10
N: Name="HDA Intel PCH Headphone"
P: Phys=ALSA
S: Sysfs=/devices/pci0000:00/0000:00:0e.0/sound/card0/input7
U: Uniq=
H: Handlers=event7
B: PROP=0
B: EV=21
B: SW=4
N: Name="HDA Intel PCH HDMI/DP,pcm=3"
P: Phys=ALSA
S: Sysfs=/devices/pci0000:00/0000:00:0e.0/sound/card0/input8
U: Uniq=
H: Handlers=event8
B: PROP=0
B: EV=21
B: SW=140
N: Name="HDA Intel PCH HDMI/DP,pcm=7"
P: Phys=ALSA
S: Sysfs=/devices/pci0000:00/0000:00:0e.0/sound/card0/input9
U: Uniq=
H: Handlers=event9
B: PROP=0
B: EV=21
B: SW=140
N: Name="HDA Intel PCH HDMI/DP,pcm=8"
P: Phys=ALSA
S: Sysfs=/devices/pci0000:00/0000:00:0e.0/sound/card0/input10
U: Uniq=
H: Handlers=event10
B: PROP=0
B: EV=21
B: SW=140
I: Bus=0003 Vendor=04f2 Product=b5d7 Version=1407
N: Name="EasyCamera"
P: Phys=usb-0000:00:15.0-7/button
S: Sysfs=/devices/pci0000:00/0000:00:15.0/usb1/1-7/1-7:1.0/input/input11
U: Uniq=
H: Handlers=kbd event11
B: PROP=0
B: EV=3
B: KEY=100000 0 0 0
I: Bus=0003 Vendor=248a Product=8366 Version=0111
N: Name="Telink 2.4G Mouse"
P: Phys=usb-0000:00:15.0-2/input0
S: Sysfs=/devices/pci0000:00/0000:00:15.0/usb1/1-2/1-2:1.0/0003:248A:8366.0002/input/input12
U: Uniq=
H: Handlers=kbd mouse0 event4
B: PROP=0
B: EV=1f
B: KEY=3007f 0 0 483ffff17aff32d bf54444600000000 1f0001 130f938b17c000 677bfad941dfed 9ed68000004400 10000002
B: REL=143
B: ABS=100000000
B: MSC=10
abulaev2008
17 дек 2017, 19:10
Да кстати, при загрузке с UEFI ошибка, пришлось ставить Legasi в Биосе
17 дек 2017, 19:52
17 дек 2017, 19:06
По выводу cat /proc/bus/input/devices тача нет.
Или тач не работает вообще, или отключен в УЕФИ.
Проверь, события от ядра на вкл. выкл. тача по fn+F6 c помощью evemu-record
event5 там нужно.
17 дек 2017, 19:10
Вот из-за этого может ещё быть проблема.
Забудьте уже про эмуляцию БИОС на современном железе.
Флешку делай конкретно для УЕФИ-ГПТ, а не гибридную или БИОС-МБР и всё загрузится и установится в УЕФИ.
17 дек 2017, 21:08
17 дек 2017, 17:30
Несколько раз было сказано, что начать надо с описания железа
В теме нет ни слова за модель ноута, производитель и модель тачсрина, его vendor и device идентификаторы, процесс опознания его udev'ом... В общем hw-probe в студию и срез сислога.
С текущей вводной инфой - можно лишь посочустововать твоей беде :sarcasm:
17 дек 2017, 21:53
17 дек 2017, 19:06
не мог ввести и не отображались вводимые символы/не отображались даже звездочки - разные вещи. В linux не отображаются ни пароль, ни звездочки. Хотя жирные точки все же бывают.
ikrost
Благодарил (а): 831 раз
17 дек 2017, 23:03
Явно в Биосе что-то. Сбрось его до заводских.
Laszcz
18 дек 2017, 15:58
В 17.3 после установки более нового ядра у меня тачпад ожил. А ну как и в 18.1 пролезет?
abulaev2008
21 дек 2017, 22:52
Был установлен Минт 18.2, не работает, ядро 4.8.0. После поиска решений в Инете обновился до 14.13.16, не работает. Сейчас установил Вин10, сначала не заработал. После установки драйвера тача с сайта Леново тоже нет. Когда установил Интеловские драйвера заработали все Fn кнопки и включился тач. Думаю в Линуксе нужны новые драйвера под Intel-Microcode. Но уже пока нет желания экспериментировать.
abulaev2008
21 дек 2017, 22:53
Извиняюсь - 4.13.16
wanoska
Благодарил (а): 40 раз
22 дек 2017, 19:51
xinput --list
⎜ ↳ SEMICCHIP Usb Mouse id=9 [slave pointer (2)]
↳ Power Button id=6 [slave keyboard (3)]
↳ Video Bus id=7 [slave keyboard (3)]
↳ Power Button id=8 [slave keyboard (3)]
↳ CNF9055 id=10 [slave keyboard (3)]
↳ Toshiba input device id=12 [slave keyboard (3)]
я так понимаю у меня не видно тачпада
Решил проблему, его действительно не было видно, так как при сборке после чистки воткнул шлейф кверхногами :-D
⎜ ↳ SynPS/2 Synaptics TouchPad id=12 [slave pointer (2)]
↳ Toshiba input device id=13 [slave keyboard (3)]
так что приношу свои извинения :)
Mihey
04 янв 2018, 17:38
Такая же проблема. На линуксе первый раз в жизни. Погуглил, но решения так и не нашел, параллельно на ноуте стоит винда 10, в ней тачпад работает.
горячие кнопки все работают кроме Fn+F4(вкл.выкл) Тача
Linux Mint 18.3 Sylvia
mikhail@mikhail-LIFEBOOK-UH572 ~ $ inxi -Fxz
System: Host: mikhail-LIFEBOOK-UH572 Kernel: 4.10.0-38-generic x86_64 (64 bit gcc: 5.4.0)
Desktop: Cinnamon 3.6.6 (Gtk 3.18.9-1ubuntu3.3)
Machine: System: FUJITSU (portable) product: LIFEBOOK UH572
Mobo: FUJITSU model: FJNBB31
Bios: FUJITSU // Phoenix v: 2.08 date: 10/17/2012
CPU: Dual core Intel Core i5-3317U (-HT-MCP-) cache: 3072 KB
flags: (lm nx sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx) bmips: 6784
clock speeds: max: 2600 MHz 1: 804 MHz 2: 801 MHz 3: 805 MHz
4: 802 MHz
Graphics: Card: Intel 3rd Gen Core processor Graphics Controller
bus-ID: 00:02.0
Resolution: 1366x768@60.03hz
GLX Renderer: Mesa DRI Intel Ivybridge Mobile
Audio: Card Intel 7 Series/C210 Series Family High Definition Audio Controller
Sound: Advanced Linux Sound Architecture v: k4.10.0-38-generic
Network: Card: Intel Centrino Wireless-N 2230
driver: iwlwifi bus-ID: 02:00.0
Drives: HDD Total Size: 276.2GB (4.9% used)
ID-1: /dev/sda model: TOSHIBA size: 240.1GB
ID-2: /dev/sdb model: SanDisk_SSD_i100 size: 32.0GB
ID-3: USB /dev/sdc model: USB size: 4.1GB
Partition: ID-1: / size: 69G used: 7.1G (11%) fs: ext4 dev: /dev/sda5
ID-2: swap-1 size: 4.15GB used: 0.04GB (1%) fs: swap dev: /dev/sda6
Sensors: System Temperatures: cpu: 55.0C mobo: N/A
Fan Speeds (in rpm): cpu: N/A
Info: Processes: 232 Uptime: 2:54 Memory: 1967.4/3809.2MB
