Не пинайте спящую собаку в зубы.
Автоматическое снижение яркости
- Решено: 13
Сам наугад тыкаю.
Попробуйте выполнить в терминале
После этого вытащить и вставить зарядку
udevadm monitor -s power_supply
у меня так
$ udevadm monitor -s power_supply
monitor will print the received events for:
UDEV - the event which udev sends out after rule processing
KERNEL - the kernel uevent
KERNEL[9387.501956] change /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:18/ACPI0003:00/power_supply/ACAD (power_supply)
UDEV [9387.546688] change /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:18/ACPI0003:00/power_supply/ACAD (power_supply)
KERNEL[9388.526094] change /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:18/PNP0C0A:00/power_supply/BAT1 (power_supply)
UDEV [9388.535777] change /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:18/PNP0C0A:00/power_supply/BAT1 (power_supply)
KERNEL[9394.493872] change /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:18/ACPI0003:00/power_supply/ACAD (power_supply)
UDEV [9394.527639] change /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:18/ACPI0003:00/power_supply/ACAD (power_supply)
KERNEL[9395.533735] change /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:18/PNP0C0A:00/power_supply/BAT1 (power_supply)
UDEV [9395.541139] change /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:18/PNP0C0A:00/power_supply/BAT1 (power_supply)
легенда
Контекстное меню Nemo
- Решено: 13
Еще
Ищите в выводе
POWER_SUPPLY_ONLINE=0
POWER_SUPPLY_ONLINE=1
udevadm monitor -p -u -s power_supply
У меня так
UDEV [9962.826388] change /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:18/ACPI0003:00/power_supply/ACAD (power_supply)
ACTION=change
DEVPATH=/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:18/ACPI0003:00/power_supply/ACAD
SUBSYSTEM=power_supply
POWER_SUPPLY_NAME=ACAD
SEQNUM=8797
USEC_INITIALIZED=9962814102
UDEV [9963.857585] change /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:18/PNP0C0A:00/power_supply/BAT1 (power_supply)
ACTION=change
DEVPATH=/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:18/PNP0C0A:00/power_supply/BAT1
POWER_SUPPLY_NAME=BAT1
POWER_SUPPLY_STATUS=Discharging
POWER_SUPPLY_PRESENT=1
POWER_SUPPLY_TECHNOLOGY=Li-ion
POWER_SUPPLY_CYCLE_COUNT=0
POWER_SUPPLY_VOLTAGE_MIN_DESIGN=15200000
POWER_SUPPLY_VOLTAGE_NOW=16855000
POWER_SUPPLY_CURRENT_NOW=0
POWER_SUPPLY_CHARGE_FULL_DESIGN=3220000
POWER_SUPPLY_CHARGE_FULL=2607000
POWER_SUPPLY_CHARGE_NOW=2602000
POWER_SUPPLY_CAPACITY=99
POWER_SUPPLY_CAPACITY_LEVEL=Normal
POWER_SUPPLY_MODEL_NAME=PABAS0241231
POWER_SUPPLY_MANUFACTURER=COMPAL
POWER_SUPPLY_SERIAL_NUMBER=41167
SEQNUM=8799
USEC_INITIALIZED=9963856473
UDEV [9971.628569] change /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:18/ACPI0003:00/power_supply/ACAD (power_supply)
ACTION=change
SEQNUM=8800
USEC_INITIALIZED=9971606581
UDEV [9972.627663] change /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:18/PNP0C0A:00/power_supply/BAT1 (power_supply)
ACTION=change
POWER_SUPPLY_STATUS=Full
POWER_SUPPLY_VOLTAGE_NOW=16595000
POWER_SUPPLY_CURRENT_NOW=503000
POWER_SUPPLY_CHARGE_NOW=2607000
POWER_SUPPLY_CAPACITY=100
POWER_SUPPLY_CAPACITY_LEVEL=Full
SEQNUM=8802
USEC_INITIALIZED=9972627080
легенда
Автор темы - Сообщения: 125
KERNEL[5930.167646] change /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/PNP0C0A:03/power_supply/BAT0 (power_supply)
UDEV [5930.466194] change /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/PNP0C0A:03/power_supply/BAT0 (power_supply)
KERNEL[5938.819429] change /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/PNP0C0A:03/power_supply/BAT0 (power_supply)
UDEV [5939.392082] change /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/PNP0C0A:03/power_supply/BAT0 (power_supply)
KERNEL[5991.171515] change /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/PNP0C0A:03/power_supply/BAT0 (power_supply)
UDEV [5991.488617] change /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/PNP0C0A:03/power_supply/BAT0 (power_supply)
KERNEL[5994.887578] change /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/PNP0C0A:03/power_supply/BAT0 (power_supply)
UDEV [5995.488029] change /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/PNP0C0A:03/power_supply/BAT0 (power_supply)
UDEV [6098.016959] change /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/PNP0C0A:03/power_supply/BAT0 (power_supply)
ACTION=change
DEVPATH=/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/PNP0C0A:03/power_supply/BAT0
POWER_SUPPLY_NAME=BAT0
POWER_SUPPLY_CYCLE_COUNT=41
POWER_SUPPLY_VOLTAGE_MIN_DESIGN=11678000
POWER_SUPPLY_VOLTAGE_NOW=12872000
POWER_SUPPLY_CURRENT_NOW=1073000
POWER_SUPPLY_CHARGE_FULL_DESIGN=4110000
POWER_SUPPLY_CHARGE_FULL=3826000
POWER_SUPPLY_CHARGE_NOW=3616000
POWER_SUPPLY_CAPACITY=94
POWER_SUPPLY_MODEL_NAME=SDI ICR18650
POWER_SUPPLY_MANUFACTURER=Simplo
POWER_SUPPLY_SERIAL_NUMBER=123456789
SEQNUM=9462
USEC_INITIALIZED=6097693654
UDEV [6123.038222] change /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/PNP0C0A:03/power_supply/BAT0 (power_supply)
ACTION=change
POWER_SUPPLY_STATUS=Charging
POWER_SUPPLY_VOLTAGE_NOW=12628000
POWER_SUPPLY_CURRENT_NOW=315000
POWER_SUPPLY_CHARGE_NOW=3611000
SEQNUM=9464
USEC_INITIALIZED=6122459663
ACTION=change
SEQNUM=9462
ACTION=change
SEQNUM=9464
- Решено: 13
Мне кажется в Вашем случае файл должен выглядеть так
PS Используйте споилеры )
SUBSYSTEM=="power_supply", ATTR{status}=="Discharging", RUN+="/usr/local/bin/powersafe.sh true"
SUBSYSTEM=="power_supply", ATTR{status}=="Charging", RUN+="/usr/local/bin/powersafe.sh false"
легенда
- Решено: 13
У меня это работает,
только в моём случае атрибут
Смотрите, что происходит в Вашем случае.
В любом случае, Вам нужен атрибут который будет менять состояние при подключении и отключении зарядки. Это будет триггером для запуска сценария.
status
указывает на состояние батареи, а не на то подключена ли зарядка.Смотрите, что происходит в Вашем случае.
Последний раз редактировалось пользователем 1 demonlibra; всего редактировалось раз: 9
легенда
Заработало!!! Огромное спасибо! Ноутбук у меня новый, но снижение яркости все-равно 1 час автономной работы добавляетdemonlibra писал(а): ↑09 фев 2021, 21:09Мне кажется в Вашем случае файл должен выглядеть такPS Используйте споилеры )Код: Выделить всё
SUBSYSTEM=="power_supply", ATTR{status}=="Discharging", RUN+="/usr/local/bin/powersafe.sh true" SUBSYSTEM=="power_supply", ATTR{status}=="Charging", RUN+="/usr/local/bin/powersafe.sh false"
- Решено: 13
Проверьте работу при не полной зарядке батареи.
Мне кажется в этом будет подвох.
легенда
Сейчас шнур выдернул, с сотни заряд стронулся, но проблем нет. Примерно на скольки процентах подвох ждать?demonlibra писал(а): ↑09 фев 2021, 21:17Проверьте работу при не полной зарядке батареи.
- Решено: 13
У меня сейчас состояние STATUS=FULL и меня это смущает.
Т.е. значение как бы намекает на состояние батареи, а не подключения зарядки.
Если работает и хорошо. Время покажет.
легенда
- Решено: 13
легенда
- Решено: 13
Добавь тогда в подпись: " Прошу полностью цитировать мои сообщения при ответе!" А то, получатца, что я "наехал" без дела. Диалоги с тобой, тоды, редактировать не буду
Ну, собственно, посадил до 87% и обратно вставил - полет нормальный. Думаю что все хорошо будет. А Вам еще раз спасибо!demonlibra писал(а): ↑09 фев 2021, 21:29У меня сейчас состояние STATUS=FULL и меня это смущает.
- Решено: 13
легенда
- Решено: 13
Тут возникает вопрос по теме,
как сделать так, чтобы автоматически выполнялся сценарий после выхода из спящего режима?
легенда
- Решено: 13
Вытащил зарядку во время работы, яркость экрана изменилась.
Ноут ушел в "Режим ожидания".
Подключил зарядку.
Вернул ноут к работе.
Яркость осталась прежней.
Как сделать так, чтобы после выхода из "Режима ожидания" выполнялась команда:
Подключил зарядку.
/usr/bin/udevadm trigger -s power_supply
Последний раз редактировалось пользователем 2 demonlibra; всего редактировалось раз: 23
легенда
