Стоят на одном SSD диске 2 одинаковых LM 20 Mate. Одна грузится минут 5, другая 10 секунд.
Благодарил (а): 1223 раза
03 ноя 2020, 02:54
Как ускорить загрузку медленной системы?
1. LM 20 x64 Ulyana
2. Mate
3. inxi -Fxz
h@h:~$ inxi -Fxz
Kernel: 5.4.0-52-generic x86_64 bits: 64 compiler: gcc v: 9.3.0
Desktop: MATE 1.24.0 Distro: Linux Mint 20 Ulyana base: Ubuntu 20.04 focal
Type: Desktop Mobo: ASUSTeK model: P8H77-V v: Rev X.0x serial: <filter>
UEFI: American Megatrends v: 1905 date: 10/27/2014
Topology: Quad Core model: Intel Core i7-3770 bits: 64 type: MT MCP
arch: Ivy Bridge rev: 9 L2 cache: 8192 KiB
flags: avx lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 54402
Speed: 3051 MHz min/max: 1600/3900 MHz Core speeds (MHz): 1: 3440 2: 3491
3: 3226 4: 2616 5: 2957 6: 3332 7: 3247 8: 3052
Device-1: NVIDIA GM206 [GeForce GTX 960] vendor: Micro-Star MSI
driver: nouveau v: kernel bus ID: 01:00.0
Display: x11 server: X.Org 1.20.8 driver: modesetting unloaded: fbdev,vesa
resolution: 1920x1200~60Hz, 1920x1080~60Hz
OpenGL: renderer: NV126 v: 4.3 Mesa 20.0.8 direct render: Yes
Device-1: Intel 7 Series/C216 Family High Definition Audio vendor: ASUSTeK
Device-2: NVIDIA GM206 High Definition Audio vendor: Micro-Star MSI
Sound Server: ALSA v: k5.4.0-52-generic
Device-1: Qualcomm Atheros AR8161 Gigabit Ethernet vendor: ASUSTeK
driver: alx v: kernel port: d000 bus ID: 03:00.0
Local Storage: total: 9.21 TiB used: 46.09 GiB (0.5%)
ID-1: /dev/sda vendor: OCZ model: VERTEX3 size: 111.79 GiB
ID-2: /dev/sdb vendor: Seagate model: ST4000DM004-2CV104 size: 3.64 TiB
ID-3: /dev/sdc vendor: Seagate model: ST6000DM003-2CY186 size: 5.46 TiB
RAID:
Hardware-1: VIA VT6421 IDE/SATA Controller driver: sata_via v: 2.6
bus ID: 05:02.0
ID-1: / size: 36.25 GiB used: 21.64 GiB (59.7%) fs: ext4 dev: /dev/sda1
ID-2: /home size: 36.31 GiB used: 24.45 GiB (67.3%) fs: ext4
dev: /dev/sda2
System Temperatures: cpu: 63.0 C mobo: N/A gpu: nouveau temp: 51 C
Fan Speeds (RPM): N/A gpu: nouveau fan: 0
Processes: 256 Uptime: 9m Memory: 15.58 GiB used: 1.78 GiB (11.4%)
inxi: 3.0.38
h@h:~$
4. systemd-analyze blame
h@h:~$ systemd-analyze blame
608ms dev-sda1.device >
581ms systemd-logind.service >
502ms lightdm.service >
498ms plymouth-quit-wait.service >
312ms udisks2.service >
305ms networkd-dispatcher.service >
229ms accounts-daemon.service >
195ms upower.service >
175ms lm-sensors.service >
157ms ubuntu-system-adjustments.service >
150ms lvm2-monitor.service >
140ms avahi-daemon.service >
139ms systemd-resolved.service >
137ms NetworkManager.service >
136ms polkit.service >
107ms networking.service >
106ms thermald.service >
104ms systemd-journald.service >
102ms wpa_supplicant.service >
100ms ModemManager.service >
98ms user@1000.service >
98ms gpu-manager.service >
97ms systemd-udev-trigger.service >
lines 1-23...skipping...
89ms swapfile.swap
84ms keyboard-setup.service
81ms e2scrub_reap.service
81ms systemd-journal-flush.service
65ms grub-common.service
62ms colord.service
61ms systemd-udevd.service
59ms hddtemp.service
55ms apparmor.service
53ms alsa-restore.service
42ms rsyslog.service
38ms grub-initrd-fallback.service
34ms ntp.service
33ms systemd-modules-load.service
25ms systemd-tmpfiles-setup.service
23ms systemd-fsck@dev-disk-by\x2duuid-f745350e\x2dcdba\x2d4905\x2da182\x2d38845ed5860b.service
18ms pppd-dns.service
14ms systemd-tmpfiles-setup-dev.service
14ms plymouth-start.service
14ms plymouth-read-write.service
13ms systemd-sysusers.service
13ms systemd-sysctl.service
13ms dev-hugepages.mount
12ms dev-mqueue.mount
12ms sys-kernel-debug.mount
11ms kerneloops.service
11ms user-runtime-dir@1000.service
11ms systemd-random-seed.service
11ms sys-kernel-tracing.mount
10ms systemd-update-utmp.service
9ms blk-availability.service
9ms systemd-remount-fs.service
8ms kmod-static-nodes.service
8ms systemd-user-sessions.service
8ms systemd-update-utmp-runlevel.service
6ms console-setup.service
5ms rtkit-daemon.service
4ms home.mount
4ms openvpn.service
4ms ufw.service
4ms sys-fs-fuse-connections.mount
lines 1-64
5. Скрин при загрузке не делается. Просто долго висит кругляшок эмблемы на черном экране, потом выскакивает логи и пароль. После ввода пароля загружается сразу
Вторая система загружается сразу - кругляшок эмблемы иногда даже не успеваю заметить.
bootchart
h@h:~$ bootchart
bash: bootchart: команда не найдена
h@h:~$
03 ноя 2020, 08:23
hellonet писал(а):
03 ноя 2020, 02:54
Так убери его и смотри на чем тупит
03 ноя 2020, 08:47
hellonet, Смотри UUID разделов в fstab .
03 ноя 2020, 10:54
А почему bootchart не работает? Или в двадцатке всё переделали по сравнению с 19.3?
03 ноя 2020, 11:02
hellonet писал(а):
03 ноя 2020, 10:54
Во первых не в тему , во вторых его и в 19.3 нету.
Systemd-analyze plot - делимся, сравниваем...
03 ноя 2020, 11:03
hellonet писал(а):
03 ноя 2020, 10:54
может потому что не установлено и не настроено systemd-analyze plot - делимся, сравниваем... (Пост Chocobo #21592)
03 ноя 2020, 11:05
03 ноя 2020, 11:02
Во первых не в тему
Как это не в тему? Админа критикуешь?
Linux mint грузится 10 минут, помогите пожалуйста (Пост Chocobo #97790)
