Не могу отключить apt-daily.service
s681
Благодарил (а): 71 раз
Сообщение s681 » 09 сен 2020, 14:17
Доброго дня всем!
  • Код: Выделить всё
    System:    Host: serg-H81M-DS2 Kernel: 4.15.0-96-generic x86_64 bits: 64 compiler: gcc v: 7.5.0
               Desktop: Cinnamon 4.2.4 wm: muffin dm: LightDM Distro: Linux Mint 19.2 Tina
               base: Ubuntu 18.04 bionic
    Machine:   Type: Desktop System: Gigabyte product: H81M-DS2 v: N/A serial: <filter> Chassis:
               type: 3 serial: <filter>
               Mobo: Gigabyte model: H81M-DS2 v: x.x serial: <filter> BIOS: American Megatrends v: F7
               date: 08/12/2015
    Battery:   Device-1: hidpp_battery_0 model: Logitech Wireless Keyboard K330 serial: <filter>
               charge: 55% status: Discharging
               Device-2: hidpp_battery_1 model: Logitech Wireless Mouse M215 2nd Gen serial: <filter>
               charge: 100% status: Discharging
    CPU:       Topology: Dual Core model: Intel Pentium G3220 bits: 64 type: MCP arch: Haswell rev: 3
               L2 cache: 3072 KiB
               flags: lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 11973
               Speed: 2830 MHz min/max: 800/3000 MHz Core speeds (MHz): 1: 2161 2: 2113
    Graphics:  Device-1: NVIDIA GK107 [GeForce GT 640] vendor: Micro-Star MSI driver: nvidia v: 435.21
               bus ID: 01:00.0 chip ID: 10de:0fc1
               Display: x11 server: X.Org 1.19.6 driver: nvidia resolution: 1920x1080~60Hz
               OpenGL: renderer: GeForce GT 640/PCIe/SSE2 v: 4.6.0 NVIDIA 435.21 direct render: Yes
    Audio:     Device-1: Intel 8 Series/C220 Series High Definition Audio vendor: Gigabyte
               driver: snd_hda_intel v: kernel bus ID: 00:1b.0 chip ID: 8086:8c20
               Device-2: NVIDIA GK107 HDMI Audio vendor: Micro-Star MSI driver: snd_hda_intel
               v: kernel bus ID: 01:00.1 chip ID: 10de:0e1b
               Sound Server: ALSA v: k4.15.0-96-generic
    Network:   Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Gigabyte
               driver: r8169 v: 2.3LK-NAPI port: d000 bus ID: 03:00.0 chip ID: 10ec:8168
    Drives:    Local Storage: total: 2.11 TiB used: 151.29 GiB (7.0%)
               ID-1: /dev/sda vendor: Western Digital model: WD20EZRX-00D8PB0 size: 1.82 TiB
               speed: 6.0 Gb/s serial: <filter>
               ID-2: /dev/sdb vendor: Western Digital model: WD3200JS-60PDB0 size: 298.09 GiB
               speed: 3.0 Gb/s serial: <filter>
    Partition: ID-1: / size: 249.81 GiB used: 151.16 GiB (60.5%) fs: ext4 dev: /dev/sdb5
               ID-2: swap-1 size: 8.08 GiB used: 130.2 MiB (1.6%) fs: swap dev: /dev/sdb1
    USB:       Hub: 1-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0 chip ID: 1d6b:0002
               Hub: 1-1:2 info: Intel ports: 4 rev: 2.0 chip ID: 8087:8008
               Hub: 2-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0 chip ID: 1d6b:0002
               Hub: 2-1:2 info: Intel ports: 6 rev: 2.0 chip ID: 8087:8000
               Hub: 3-0:1 info: Full speed (or root) Hub ports: 10 rev: 2.0 chip ID: 1d6b:0002
               Device-1: 3-1:2 info: Logitech Unifying Receiver type: Keyboard,Mouse,HID
               driver: logitech-djreceiver,usbhid rev: 2.0 chip ID: 046d:c52b
               Hub: 4-0:1 info: Full speed (or root) Hub ports: 2 rev: 3.0 chip ID: 1d6b:0003
    Sensors:   System Temperatures: cpu: 29.8 C mobo: 27.8 C gpu: nvidia temp: 33 C
               Fan Speeds (RPM): N/A gpu: nvidia fan: 40%
    Repos:     No active apt repos in: /etc/apt/sources.list
               Active apt repos in: /etc/apt/sources.list.d/additional-repositories.list
               1: deb https: //dl.winehq.org/wine-builds/ubuntu/ bionic main
               2: deb https: //download.opensuse.org/repositories/Emulators:/Wine:/Debian/xUbuntu_18.04/ ./
               1: deb http: //packages.linuxmint.com tina main upstream import backport #id:linuxmint_main
               2: deb http: //archive.ubuntu.com/ubuntu bionic main restricted universe multiverse
               3: deb http: //archive.ubuntu.com/ubuntu bionic-updates main restricted universe multiverse
               4: deb http: //archive.ubuntu.com/ubuntu bionic-backports main restricted universe multiverse
               5: deb http: //security.ubuntu.com/ubuntu/ bionic-security main restricted universe multiverse
               6: deb http: //archive.canonical.com/ubuntu/ bionic partner
    Info:      Processes: 184 Uptime: 3h 16m Memory: 5.78 GiB used: 1.23 GiB (21.4%) Init: systemd
               v: 237 runlevel: 5 Compilers: gcc: 7.5.0 alt: 7 Client: Unknown python3.6 client
               inxi: 3.0.32
Решил отключить apt-daily.service, тормозит загрузку
  • serg@serg-H81M-DS2:~$ systemd-analyze blame
    32.414s apt-daily.service
    16.612s dev-sdb5.device
    16.256s systemd-journal-flush.service
    14.832s systemd-modules-load.service
    14.479s kmod-static-nodes.service
    9.233s keyboard-setup.service
    4.921s NetworkManager.service
    4.636s winbind.service
    4.558s ubuntu-system-adjustments.service
    4.509s networkd-dispatcher.service
    3.519s udisks2.service
    3.066s systemd-random-seed.service
    2.924s accounts-daemon.service
    2.749s gpm.service
    1.990s wpa_supplicant.service
    1.805s setvtrgb.service
Выполняю
sudo systemctl stop apt-daily.service
sudo systemctl disable apt-daily.service
На следующий день опять вижу его в тормозах при загрузке. Что не так делаю?
Решение symon2014 » 09 сен 2020, 14:28
s681 писал(а):
09 сен 2020, 14:17
Что не так делаю?
Добавь ещё после дисабле -- sudo systemctl mask apt-daily.service
Сообщение symon2014 » 09 сен 2020, 14:28
s681 писал(а):
09 сен 2020, 14:17
Что не так делаю?
s681
Сообщение s681 » 09 сен 2020, 14:32
Спасибо, сейчас сделаю.
s681
Сообщение s681 » 09 сен 2020, 14:35
И еще, не могу нормально отформатировать сообщение. Вывод терминала отобразился только так.
s681
Сообщение s681 » 09 сен 2020, 14:38
09 сен 2020, 14:28
Маскировать нужно все сервисы, которые отключаю?
Сообщение Chocobo » 09 сен 2020, 14:44
s681, disable отключает юнит из автозагрузки, не отменяя его запуска в случае сквозь зависимые от него юниты.
mask вообще напрочь убирает у него возможность хоть как-то запуститься.
Сообщение symon2014 » 09 сен 2020, 14:48
s681 писал(а):
09 сен 2020, 14:38
Нет.
Сообщение rogoznik » 09 сен 2020, 15:31
s681 писал(а):
09 сен 2020, 14:35
Что-то не так делаешь. Почитай Панель форматирования текста в темах/ответах
