Создание загрузочной usb-флешки Win10 в LM20
Numenorian
Сообщение Numenorian » 11 авг 2020, 19:14
вывод inxi -Fxz
Kernel: 5.4.0-42-generic x86_64 bits: 64 compiler: gcc v: 9.3.0
Desktop: Cinnamon 4.6.6 Distro: Linux Mint 20 Ulyana
base: Ubuntu 20.04 focal
Type: Laptop System: Sony product: VPCEB1E1R v: C603S026 serial: <filter>
Mobo: Sony model: VAIO serial: <filter> BIOS: American Megatrends
v: R0220Y8 date: 01/12/2010
Topology: Dual Core model: Intel Core i3 M 330 bits: 64 type: MT MCP
arch: Nehalem rev: 2 L2 cache: 3072 KiB
flags: lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 17025
Speed: 1350 MHz min/max: 933/2133 MHz Core speeds (MHz): 1: 1335 2: 1353
3: 1240 4: 1127
Device-1: AMD Park [Mobility Radeon HD 5430/5450/5470] vendor: Sony
driver: radeon v: kernel bus ID: 01:00.0
Display: x11 server: X.Org 1.20.8 driver: ati,radeon
unloaded: fbdev,modesetting,vesa resolution: 1366x768~60Hz
OpenGL: renderer: AMD CEDAR (DRM 2.50.0 / 5.4.0-42-generic LLVM 10.0.0)
v: 3.3 Mesa 20.0.8 direct render: Yes
Device-1: Intel 5 Series/3400 Series High Definition Audio vendor: Sony
Device-2: AMD Cedar HDMI Audio [Radeon HD 5400/6300/7300 Series]
vendor: Sony driver: snd_hda_intel v: kernel bus ID: 01:00.1
Device-3: JMTek LLC. type: USB driver: hid-generic,snd-usb-audio,usbhid
bus ID: 2-1.5:3
Sound Server: ALSA v: k5.4.0-42-generic
Device-1: Qualcomm Atheros AR9285 Wireless Network Adapter
vendor: Foxconn T77H126.00 802.11bgn driver: ath9k v: kernel port: d000
bus ID: 02:00.0
IF: wlp2s0 state: down mac: <filter>
Device-2: Marvell Yukon Optima 88E8059 [PCIe Gigabit Ethernet with AVB]
vendor: Sony driver: sky2 v: 1.30 port: a000 bus ID: 04:00.0
Local Storage: total: 312.65 GiB used: 41.88 GiB (13.4%)
ID-1: /dev/sda vendor: Toshiba model: MK3265GSX size: 298.09 GiB
ID-2: /dev/sdb type: USB vendor: Transcend model: JetFlash Transcend 16GB
ID-1: / size: 27.37 GiB used: 7.97 GiB (29.1%) fs: ext4 dev: /dev/sda1
ID-2: /home size: 261.24 GiB used: 20.24 GiB (7.7%) fs: ext4
dev: /dev/sda6
ID-3: swap-1 size: 3.72 GiB used: 0 KiB (0.0%) fs: swap dev: /dev/sda5
System Temperatures: cpu: 52.0 C mobo: 52.0 C gpu: radeon temp: 53 C
Processes: 235 Uptime: 8m Memory: 3.70 GiB used: 1.62 GiB (43.9%)
inxi: 3.0.38
WoeUSB не ставится через терминал, не может найти пакет с таким именем.
Пробовал через dd, такой командой - sudo dd if=image.iso of=/dev/sdb bs=2048
dev/sdb видит только если смонтирована, если ее размонтировать, пишет что невозможно открыть dev/sdb
Записал на смонтированную, проверял через ls -l /mnt/, показывает "итого 0", хотя флешка записана, файлы на ней есть, но при перезагрузке не бутится. Флешка отформатирована в ntfs через GP, флаги boot не ставил. Образ WIn10
Вывод sudo blkid /dev/sdb
/dev/sdb: UUID="5a6211fe5a62119c" LABEL="10x64_StartSoft_03_2018" TYPE="udf"
вывод $ ls -l /mnt/
итого 0
Последний раз редактировалось пользователем 2 Numenorian; всего редактировалось раз: 11
Сообщение symon2014 » 11 авг 2020, 19:24
Numenorian, Что то много непонятных букаф в описании задачи. Самая интересная фича для правильной работы woeUSB , нужно отмонтировать не флешку а раздел на флешке.
Numenorian
Сообщение Numenorian » 11 авг 2020, 19:28
11 авг 2020, 19:24
Каким образом его поставить?
Через sudo add-apt-repository ppa:nilarimogard/webupd8
sudo apt-get update
sudo apt-get install woeusb
Ошибка E: Невозможно найти пакет woeusb
Сообщение symon2014 » 11 авг 2020, 19:33
apt search woeusb
Numenorian
Сообщение Numenorian » 11 авг 2020, 19:51
11 авг 2020, 19:33
apt search woeusb
пусто
Сообщение symon2014 » 11 авг 2020, 19:53
https://launchpad.net/~nilarimogard/+ar ... &start=600
бери пакет для своей версии и поставь сам.
Сообщение rogoznik » 11 авг 2020, 20:07
Numenorian, учитесь пользоваться поиском
Создание загрузочного носителя UEFI (флешки и прочее) без спецпрограмм - инструкция.
С вин10 точно поможет
Благодарил (а): 26 раз
Сообщение 027 » 12 авг 2020, 00:21
Numenorian писал(а):
11 авг 2020, 19:51
пусто
$ apt search woeusb
p   woeusb        - Bootable Windows installation/PE USB storage creator
(репа ppa:nilarimogard/webupd8 у меня всегда подключена)
11 авг 2020, 19:51
пусто
Не иначе apt update не сделал.
