Установка драйвера видеокарты AMD
acetone
Благодарил (а): 2 раза
Сообщение acetone » 13 сен 2016, 08:14
AMD RADEON HD5250 - довольно древний экземпляр, но с драйверами под виндой устраивало.
Скачал я *.run пакет, запустил его через консоль аля sh ~/amd-catalyst-13.12-linux-x86.x86_64.run и вышла ошибка
Created directory fglrx-install.9Fs5mc
Verifying archive integrity... All good.
Uncompressing AMD Catalyst(TM) Proprietary Driver-13.251...........................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................
AMD Catalyst(TM) Proprietary Driver Installer/Packager
error: Detected X Server version 'XServer 1.18.3_64a' is not supported. Supported versions are X.Org 6.9 or later, up to XServer 1.10 (default:v2:x86_64:lib32:XServer 1.18.3_64a:none:4.4.0-21-generic:)
Installation will not proceed.
Removing temporary directory: fglrx-install.9Fs5mc
Что делать, товарищи?
Re: Установка драйвера видеокарты AMD
Сообщение Chocobo » 13 сен 2016, 08:49
acetone, это один из самых животрепещущих вопросов с выходом 16.04 и Минт 18 :smile:
Вот здесь например уже обсуждали.
Других вариантов пока не предвидится, разве что еще ручной даунгрейд иксов до последней совместимой версии - но там тоже неизвестно сколько трудов потребуется чтоб оно заработало...
Сообщение symon2014 » 13 сен 2016, 08:50
Молиться, начиная с 18 минта и 16.04 убунту AMD перестало оказывать поддержку, о чём было оффициальное заявление. Так что или использовать свободный, или поставить 17.3 , примерно так.
acetone
Сообщение acetone » 13 сен 2016, 12:41
symon2014 писал(а): Так что или использовать свободный, или поставить 17.3 , примерно так.
17.3 Mint или речь о дровах? Прошу уточнить, я слишком темный в этом деле нынче :crazy:
Сообщение Chocobo » 13 сен 2016, 12:49
acetone писал(а): 17.3 Mint
:yes:
acetone
Сообщение acetone » 13 сен 2016, 14:55
:yes:
Тогда еще один вопрос: можно понизить версию с 18 до 17.3? Не хочется терять всю поставленную софтину и настройки, нет времени)
Сообщение Chocobo » 13 сен 2016, 15:01
acetone, тут есть вариант переустановки без потерь, если /home вынесен на отдельный раздел
Прямого даунгрейда релиза не предусмотрено
Сообщение symon2014 » 13 сен 2016, 15:06
Настройки и данные сохранятся, но если что то ставил дополнительно, придётся поставить заново, но и в этом случае настройки останутся, главное не форматировать хомяк. И ещё если раздел один, вместе с хомяком, просто не форматировать его, а ставить поверху.
acetone
Сообщение acetone » 13 сен 2016, 20:59
symon2014 писал(а): Настройки и данные сохранятся, но если что то ставил дополнительно, придётся поставить заново, но и в этом случае настройки останутся, главное не форматировать хомяк. И ещё если раздел один, вместе с хомяком, просто не форматировать его, а ставить поверху.
Ого) да, на скорую руку забыл и про монтирование хомяка и про все на свете. Если поставить по верх всего не форматируя, то нормально будет? Что-то я в сомнениях :crazy: :dance:
Сообщение symon2014 » 13 сен 2016, 21:14
acetone, Если не ставить галку форматировать , ничего с настройками не будет, сам пробовал. С корня удалятся только те проги которые ставил саь отдельно, а хомяк вооюще останется в неприкосновенности. Кстати Cocobo сейчас мучает лм18, ставит на него хорг от 17.3, чтобы амд драйвера ставились, посмотри чат или жабу.
Вернуться в «Видеокарты»
