Правильная настройка звуковой карты/драйвера в LinuxMint 19.3 Tricia
Нет звука? Вас не устраивает качество звучания? Вы попали по адресу.
AliceCooper
Благодарил (а): 10 раз
Сообщение AliceCooper » 19 май 2020, 03:01
Сзади подключены колонки Sven с сабом + микрофон через USB. Спереди уши.
System: Host: jasmine Kernel: 5.3.0-51-generic x86_64 bits: 64 compiler: gcc v: 7.5.0 Desktop: Xfce 4.14.1
Machine: Type: Desktop System: ASUS product: All Series v: N/A serial: <filter>
Mobo: ASUSTeK model: H81M-R v: Rev X.0x serial: <filter> BIOS: American Megatrends v: 3602 date: 03/26/2018
CPU: Topology: Dual Core model: Intel Core i3-4170 bits: 64 type: MT MCP arch: Haswell rev: 3 L2 cache: 3072 KiB
flags: lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 29532
Speed: 834 MHz min/max: 800/3700 MHz Core speeds (MHz): 1: 798 2: 798 3: 798 4: 798
Graphics: Device-1: NVIDIA GM206 [GeForce GTX 950] vendor: Micro-Star MSI driver: nvidia v: 440.59 bus ID: 01:00.0
Display: x11 server: X.Org 1.20.5 driver: nvidia unloaded: fbdev,modesetting,nouveau,vesa
resolution: 1920x1080~60Hz
OpenGL: renderer: GeForce GTX 950/PCIe/SSE2 v: 4.6.0 NVIDIA 440.59 direct render: Yes
Audio: Device-1: Intel 8 Series/C220 Series High Definition Audio vendor: ASUSTeK driver: snd_hda_intel v: kernel
bus ID: 00:1b.0
Device-2: NVIDIA vendor: Micro-Star MSI driver: snd_hda_intel v: kernel bus ID: 01:00.1
Sound Server: ALSA v: k5.3.0-51-generic
Network: Device-1: Qualcomm Atheros AR9485 Wireless Network Adapter driver: ath9k v: kernel port: e000 bus ID: 03:00.0
Device-2: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: ASUSTeK driver: r8169 v: kernel port: d000
bus ID: 04:00.0
Drives: Local Storage: total: 931.51 GiB used: 90.59 GiB (9.7%)
ID-1: /dev/sda vendor: Western Digital model: WD10EZRZ-00HTKB0 size: 931.51 GiB
Partition: ID-1: / size: 915.89 GiB used: 45.30 GiB (4.9%) fs: ext4 dev: /dev/sda1
ID-2: swap-1 size: 2.00 GiB used: 0 KiB (0.0%) fs: swap dev: /dev/dm-0
Sensors: System Temperatures: cpu: 33.0 C mobo: N/A gpu: nvidia temp: 30 C
Fan Speeds (RPM): cpu: 0 gpu: nvidia fan: 42%
Info: Processes: 212 Uptime: 2h 19m Memory: 7.71 GiB used: 2.22 GiB (28.8%) Init: systemd runlevel: 5 Compilers:
gcc: 7.5.0 Shell: bash v: 4.4.20 inxi: 3.0.32
Проблема: не разделяется звук (например, музыка в колонки, Counter-Strike Source/Dota2 в уши). в Discord работает странно (пишет звук с колонок, а мой голос не слышит).
Кто устанавливал Realtek драйверы в линьку? Поделитесь опытом. сорян, если было.
Ввожу от обычного юзверя pacmd list-cardsкоманду (я так понял показывает че есть ваще)
2 card(s) available.
    index: 0
	driver: <module-alsa-card.c>
	owner module: 7
	properties:
		alsa.card = "1"
		alsa.card_name = "HDA NVidia"
		alsa.long_card_name = "HDA NVidia at 0xf7080000 irq 17"
		alsa.driver_name = "snd_hda_intel"
		device.bus_path = "pci-0000:01:00.1"
		sysfs.path = "/devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1"
		device.bus = "pci"
		device.vendor.id = "10de"
		device.vendor.name = "NVIDIA Corporation"
		device.product.id = "0fba"
		device.string = "1"
		device.description = "HDA NVidia"
		module-udev-detect.discovered = "1"
		device.icon_name = "audio-card-pci"
	profiles:
		output:hdmi-stereo: Digital Stereo (HDMI) выход (priority 5400, available: no)
		output:hdmi-surround: Digital Surround 5.1 (HDMI) выход (priority 300, available: no)
		output:hdmi-surround71: Digital Surround 7.1 (HDMI) выход (priority 300, available: no)
		output:hdmi-stereo-extra1: Digital Stereo (HDMI 2) выход (priority 5200, available: no)
		output:hdmi-surround-extra1: Digital Surround 5.1 (HDMI 2) выход (priority 100, available: no)
		output:hdmi-surround71-extra1: Digital Surround 7.1 (HDMI 2) выход (priority 100, available: no)
		output:hdmi-stereo-extra2: Digital Stereo (HDMI 3) выход (priority 5200, available: no)
		output:hdmi-surround-extra2: Digital Surround 5.1 (HDMI 3) выход (priority 100, available: no)
		output:hdmi-surround71-extra2: Digital Surround 7.1 (HDMI 3) выход (priority 100, available: no)
		off: Выключено (priority 0, available: unknown)
	active profile: <off>
	ports:
		hdmi-output-0: HDMI / DisplayPort (priority 5900, latency offset 0 usec, available: no)
			properties:
				device.icon_name = "video-display"
		hdmi-output-1: HDMI / DisplayPort 2 (priority 5800, latency offset 0 usec, available: no)
			properties:
		hdmi-output-2: HDMI / DisplayPort 3 (priority 5700, latency offset 0 usec, available: no)
			properties:
    index: 1
	owner module: 8
	properties:
		alsa.card = "0"
		alsa.card_name = "HDA Intel PCH"
		alsa.long_card_name = "HDA Intel PCH at 0xf7310000 irq 32"
		device.bus_path = "pci-0000:00:1b.0"
		sysfs.path = "/devices/pci0000:00/0000:00:1b.0/sound/card0"
		device.bus = "pci"
		device.vendor.id = "8086"
		device.vendor.name = "Intel Corporation"
		device.product.id = "8c20"
		device.product.name = "8 Series/C220 Series Chipset High Definition Audio Controller"
		device.form_factor = "internal"
		device.string = "0"
		device.description = "Встроенное аудио"
	profiles:
		input:analog-stereo: Аналоговый стерео вход (priority 60, available: unknown)
		output:analog-stereo: Аналоговый стерео выход (priority 6000, available: unknown)
		output:analog-stereo+input:analog-stereo: Аналоговый стерео дуплекс (priority 6060, available: unknown)
	active profile: <output:analog-stereo+input:analog-stereo>
	sinks:
		alsa_output.pci-0000_00_1b.0.analog-stereo/#0: Встроенное аудио Аналоговый стерео
	sources:
		alsa_output.pci-0000_00_1b.0.analog-stereo.monitor/#0: Monitor of Встроенное аудио Аналоговый стерео
		alsa_input.pci-0000_00_1b.0.analog-stereo/#1: Встроенное аудио Аналоговый стерео
	ports:
		analog-input-front-mic: Фронтальный микрофон (priority 8500, latency offset 0 usec, available: no)
			properties:
				device.icon_name = "audio-input-microphone"
		analog-input-rear-mic: Тыловой микрофон (priority 8200, latency offset 0 usec, available: yes)
			properties:
		analog-input-linein: Линейный вход (priority 8100, latency offset 0 usec, available: no)
			properties:
		analog-output-lineout: Линейный выход (priority 9900, latency offset 0 usec, available: yes)
			properties:
		analog-output-headphones: Аналоговые наушники (priority 9000, latency offset 0 usec, available: no)
			properties:
				device.icon_name = "audio-headphones"
Далее так же от юзера ввожу pacmd list-sinks (эту, как сказали, надо тестить с включенным музлом, видео, микро, что бы показать что активно)
    index: 0
	owner module: 7
	properties:
		alsa.card = "1"
		device.bus = "pci"
		device.string = "1"
	profiles:
	ports:
			properties:
			properties:
			properties:
    index: 1
	owner module: 8
	properties:
		alsa.card = "0"
		device.bus = "pci"
		device.string = "0"
	profiles:
	sinks:
	sources:
	ports:
			properties:
			properties:
			properties:
			properties:
			properties:
Погуглив инфу про звук в линукс, понял что для новичка в пару кнопок не обойтись. Матерые есть?
А, вот еще инфа из "Отчеты системы"
           Desktop: Xfce 4.14.1 tk: Gtk 3.22.30 wm: xfwm4 dm: LightDM
           Speed: 3692 MHz min/max: 800/3700 MHz Core speeds (MHz): 1: 3692 2: 3692 3: 3692
           4: 3692
           v: 440.59 bus ID: 01:00.0 chip ID: 10de:1402
           unloaded: fbdev,modesetting,nouveau,vesa resolution: 1920x1080~60Hz
           driver: snd_hda_intel v: kernel bus ID: 00:1b.0 chip ID: 8086:8c20
           chip ID: 10de:0fba
           port: e000 bus ID: 03:00.0 chip ID: 168c:0032
           driver: r8169 v: kernel port: d000 bus ID: 04:00.0 chip ID: 10ec:8168
Drives:    Local Storage: total: 931.51 GiB used: 90.42 GiB (9.7%)
           speed: 6.0 Gb/s serial: <filter>
Partition: ID-1: / size: 915.89 GiB used: 45.21 GiB (4.9%) fs: ext4 dev: /dev/sda1
USB:       Hub: 1-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0 chip ID: 1d6b:0002
           Hub: 1-1:2 info: Intel ports: 4 rev: 2.0 chip ID: 8087:8008
           Hub: 2-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0 chip ID: 1d6b:0002
           Hub: 2-1:2 info: Intel ports: 6 rev: 2.0 chip ID: 8087:8000
           Hub: 3-0:1 info: Full speed (or root) Hub ports: 10 rev: 2.0 chip ID: 1d6b:0002
           Hub: 3-3:2 info: Full speed (or root) Hub ports: 4 rev: 2.0 chip ID: 214b:7250
           Device-1: 3-4:3 info: A4Tech XL-730K / XL-750BK / XL-755BK Mice type: Keyboard,Mouse
           driver: hid-generic,usbhid rev: 1.1 chip ID: 09da:9090
           Hub: 4-0:1 info: Full speed (or root) Hub ports: 2 rev: 3.0 chip ID: 1d6b:0003
Sensors:   System Temperatures: cpu: 40.0 C mobo: N/A gpu: nvidia temp: 30 C
Repos:     No active apt repos in: /etc/apt/sources.list
           1: deb http: //mirrors.evowise.com/linuxmint/packages tricia main upstream import backport
           2: deb http: //mirror.corbina.net/ubuntu bionic main restricted universe multiverse
           3: deb http: //mirror.corbina.net/ubuntu bionic-updates main restricted universe multiverse
           4: deb http: //mirror.corbina.net/ubuntu bionic-backports main restricted universe multiverse
           5: deb http: //security.ubuntu.com/ubuntu/ bionic-security main restricted universe multiverse
           6: deb http: //archive.canonical.com/ubuntu/ bionic partner
Info:      Processes: 214 Uptime: 1h 38m Memory: 7.71 GiB used: 2.12 GiB (27.5%) Init: systemd
           v: 237 runlevel: 5 Compilers: gcc: 7.5.0 alt: 7 Client: Unknown python3.6 client
           inxi: 3.0.32
а! еще же есть lspci
00:00.0 Host bridge: Intel Corporation 4th Gen Core Processor DRAM Controller (rev 06)
00:01.0 PCI bridge: Intel Corporation Xeon E3-1200 v3/4th Gen Core Processor PCI Express x16 Controller (rev 06)
00:14.0 USB controller: Intel Corporation 8 Series/C220 Series Chipset Family USB xHCI (rev 05)
00:16.0 Communication controller: Intel Corporation 8 Series/C220 Series Chipset Family MEI Controller #1 (rev 04)
00:1a.0 USB controller: Intel Corporation 8 Series/C220 Series Chipset Family USB EHCI #2 (rev 05)
00:1b.0 Audio device: Intel Corporation 8 Series/C220 Series Chipset High Definition Audio Controller (rev 05)
00:1c.0 PCI bridge: Intel Corporation 8 Series/C220 Series Chipset Family PCI Express Root Port #1 (rev d5)
00:1c.1 PCI bridge: Intel Corporation 8 Series/C220 Series Chipset Family PCI Express Root Port #2 (rev d5)
00:1c.2 PCI bridge: Intel Corporation 8 Series/C220 Series Chipset Family PCI Express Root Port #3 (rev d5)
00:1d.0 USB controller: Intel Corporation 8 Series/C220 Series Chipset Family USB EHCI #1 (rev 05)
00:1f.0 ISA bridge: Intel Corporation H81 Express LPC Controller (rev 05)
00:1f.2 SATA controller: Intel Corporation 8 Series/C220 Series Chipset Family 6-port SATA Controller 1 [AHCI mode] (rev 05)
00:1f.3 SMBus: Intel Corporation 8 Series/C220 Series Chipset Family SMBus Controller (rev 05)
01:00.0 VGA compatible controller: NVIDIA Corporation GM206 [GeForce GTX 950] (rev a1)
01:00.1 Audio device: NVIDIA Corporation Device 0fba (rev a1)
03:00.0 Network controller: Qualcomm Atheros AR9485 Wireless Network Adapter (rev 01)
04:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller (rev 11)
Разве тут все ок? Как минимум странно...
BOREDOM IS THE FIRST STEP TO RELAPSE ©
Сообщение rogoznik » 19 май 2020, 07:09
AliceCooper писал(а):
19 май 2020, 03:01
У меня такое работает "из коробки" только в KDE, и то для "ушей" у меня отдельная комплектная звуковуха. Можно для каждого приложения, которое в воспроизводит звук в данный момент, указать на какое устройство его выводить. В других DE такое настроить не смог - просто переключает вывод либо на одну звуковух, либо на другую.
Сообщение slant » 19 май 2020, 08:32
rogoznik, даже через расширенный микшер pavucontrol ? Странно. Обычно там всегда есть возможность раскидать на уровне отдельных приложений по желаемым выводам...
Сообщение rogoznik » 19 май 2020, 08:33
slant, а вот про него я как то и не вспомнил тогда, а сейчас KDE у меня, и все и так работает
AliceCooper
Сообщение AliceCooper » 19 май 2020, 11:36
rogoznik, ну я тоже так подумал можно сделать. но видимо не судьба. вообще сказал товарищ что так играя с настройками от незнания можно уронить динамики и будут декоративные подставки или горшки для цветов на даче))
запугал конкретно, и вот собственно ссусь, и как бы границы определить, чтоб не наворотить лишнего.
AliceCooper
Сообщение AliceCooper » 19 май 2020, 11:37
товарищ заканчивает по айти инстак. поэтому прислушиваюсь. если че)
Сообщение rogoznik » 19 май 2020, 12:18
19 май 2020, 11:36
А где связь между "настройками канала вывода звука" и "испортить динамики"?
19 май 2020, 11:37
Зря, херню он говорит
Сообщение symon2014 » 19 май 2020, 12:19
19 май 2020, 12:18
Поддерживаю.
Вернуться в «Звуковые карты»
