Почему выдает ошибку eclipse java
cat2cat
Благодарил (а): 9 раз
04 фев 2018, 15:38
!SESSION 2018-02-04 17:36:36.875 -----------------------------------------------
eclipse.buildId=debbuild
java.version=9.0.4
java.vendor=Oracle Corporation
BootLoader constants: OS=linux, ARCH=x86_64, WS=gtk, NL=ru_RU
Command-line arguments: -os linux -ws gtk -arch x86_64
!ENTRY org.eclipse.equinox.simpleconfigurator 4 0 2018-02-04 17:36:37.499
!MESSAGE FrameworkEvent ERROR
!STACK 0
org.osgi.framework.BundleException: The bundle "org.eclipse.equinox.simpleconfigurator_1.0.301.dist [1]" could not be resolved. Reason: Missing Constraint: Bundle-RequiredExecutionEnvironment: CDC-1.1/Foundation-1.1,J2SE-1.4
at org.eclipse.osgi.framework.internal.core.AbstractBundle.getResolverError(AbstractBundle.java:1332)
at org.eclipse.osgi.framework.internal.core.AbstractBundle.getResolutionFailureException(AbstractBundle.java:1316)
at org.eclipse.osgi.framework.internal.core.BundleHost.startWorker(BundleHost.java:323)
at org.eclipse.osgi.framework.internal.core.AbstractBundle.resume(AbstractBundle.java:390)
at org.eclipse.osgi.framework.internal.core.Framework.resumeBundle(Framework.java:1176)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.resumeBundles(StartLevelManager.java:559)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.resumeBundles(StartLevelManager.java:544)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.incFWSL(StartLevelManager.java:457)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.doSetStartLevel(StartLevelManager.java:243)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.dispatchEvent(StartLevelManager.java:438)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.dispatchEvent(StartLevelManager.java:1)
at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230)
at org.eclipse.osgi.framework.eventmgr.EventManager$EventThread.run(EventManager.java:340)
!ENTRY org.eclipse.osgi 4 0 2018-02-04 17:36:37.507
!MESSAGE Bundle initial@reference:file:plugins/org.eclipse.equinox.simpleconfigurator_1.0.301.dist.jar was not resolved.
!ENTRY org.eclipse.osgi 2 0 2018-02-04 17:36:37.516
!MESSAGE One or more bundles are not resolved because the following root constraints are not resolved:
!SUBENTRY 1 org.eclipse.osgi 2 0 2018-02-04 17:36:37.516
!SUBENTRY 2 org.eclipse.equinox.simpleconfigurator 2 0 2018-02-04 17:36:37.516
!MESSAGE Missing required capability Require-Capability: osgi.ee; filter="(|(&(osgi.ee=CDC/Foundation)(version=1.1))(&(osgi.ee=JavaSE)(version=1.4)))".
!ENTRY org.eclipse.osgi 2 0 2018-02-04 17:36:37.518
!MESSAGE The following is a complete list of bundles which are not resolved, see the prior log entry for the root cause if it exists:
!SUBENTRY 1 org.eclipse.osgi 2 0 2018-02-04 17:36:37.518
!MESSAGE Bundle org.eclipse.equinox.simpleconfigurator_1.0.301.dist [1] was not resolved.
!SUBENTRY 2 org.eclipse.equinox.simpleconfigurator 2 0 2018-02-04 17:36:37.518
!ENTRY org.eclipse.osgi 4 0 2018-02-04 17:36:37.528
!MESSAGE Application error
!STACK 1
java.lang.IllegalStateException: Unable to acquire application service. Ensure that the org.eclipse.core.runtime bundle is resolved and started (see config.ini).
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:74)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:353)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:180)
at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
at java.base/jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.base/java.lang.reflect.Method.invoke(Method.java:564)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:629)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:584)
at org.eclipse.equinox.launcher.Main.run(Main.java:1438)
at org.eclipse.equinox.launcher.Main.main(Main.java:1414)
 ! Сообщение из: darkfenix
Не первый день на форуме, уже должны уметь пользоваться Панель форматирования текста в темах/ответах
Последний раз редактировалось пользователем 1 rogoznik; всего редактировалось раз: 4
Причина: BBcode
Решено: 129
Благодарил (а): 776 раз
04 фев 2018, 16:34
А теперь думаем добавляем всю необходимую информацию, тут нет экстрасенсов.
1. Версия Eclipce
2. Версия java
3. Что вы такого делаете что появляется эта ошибка?
svtv1
Благодарил (а): 39 раз
04 фев 2018, 16:39
Может с этого (у меня, твой другой)
~ $ java --version
Приложение 'java' может быть найдено в следующих пакетах:
* default-jre
* gcj-5-jre-headless
* openjdk-8-jre-headless
* gcj-4.8-jre-headless
* gcj-4.9-jre-headless
* openjdk-9-jre-headless
Попробуйте: sudo apt install <выбранный пакет>
cat2cat
04 фев 2018, 16:55
04 фев 2018, 16:34
1. Версия Eclipce
2. Версия java
JDK 9
eclips изначально вроде по левой инструкции поставил вроде 3.8 (вылетает сразу)
(вроде так sudo apt-get install eclipse уже забыл может еще что-то в конце дописывал этой команды)
потом поставил по этой инструкции https://losst.ru/ustanovka-eclipse-v-ubuntu-16-04
он запустился и прекрасно работал (это с официального сайта версия декабрь 2017 года)
но когда я его закрыл то все закончилось - ярлыков в меню и на рабочем столе на него нет
запустить повторно его не могу
Последний раз редактировалось пользователем 2 cat2cat; всего редактировалось раз: 4
cat2cat
04 фев 2018, 16:56
svtv1 писал(а):
04 фев 2018, 16:39
~ $ java --version
java 9.0.4
Java(TM) SE Runtime Environment (build 9.0.4+11)
Java HotSpot(TM) 64-Bit Server VM (build 9.0.4+11, mixed mode)
cat2cat
04 фев 2018, 17:04
и как снести 1ую неудачную версию eclips
он пытаестя запуститься чере консоль по команде eclipse
a по команде sudo apt-get remove eclipse пишет что нет такого пакета
cat2cat
04 фев 2018, 17:06
idea@cat ~ $ eclipse
Java HotSpot(TM) 64-Bit Server VM warning: Ignoring option MaxPermSize; support was removed in 8.0
WARNING: An illegal reflective access operation has occurred
WARNING: Illegal reflective access by org.eclipse.osgi.internal.baseadaptor.BaseStorage (file:/usr/lib/eclipse/plugins/org.eclipse.osgi_3.8.1.dist.jar) to method java.net.URLClassLoader.addURL(java.net.URL)
WARNING: Please consider reporting this to the maintainers of org.eclipse.osgi.internal.baseadaptor.BaseStorage
WARNING: Use --illegal-access=warn to enable warnings of further illegal reflective access operations
WARNING: All illegal access operations will be denied in a future release
idea@cat ~ $ sudo apt-get remove eclipse
[sudo] пароль для idea:
Пакет «eclipse» не установлен, поэтому не может быть удалён
обновлено 0, установлено 0 новых пакетов, для удаления отмечено 0 пакетов, и 340 пакетов не обновлено.
idea@cat ~ $
Решено: 129
04 фев 2018, 17:08
cat2cat писал(а):
04 фев 2018, 16:55
Какой вариант использовал 1 или 2?
cat2cat
04 фев 2018, 17:10
04 фев 2018, 17:08
вот этот работал у меня https://losst.ru/ustanovka-eclipse-v-ubuntu-16-04
но когда я его закрыл ярлыки не создались хоть я и делал все как по ссылке
Решено: 129
04 фев 2018, 17:12
Блин там 2 варианта установки
Установка Eclipse на Ubuntu
Установка Eclipse с помощью apt
Как ты ставил?
cat2cat
04 фев 2018, 17:16
04 фев 2018, 17:12
Как ты ставил?
оба варианта
через apt
и через этот путем компиляции архива *.tar.gz https://losst.ru/ustanovka-eclipse-v-ubuntu-16-04
видимо старую и новую версию одновременно установил
svtv1
04 фев 2018, 17:19
Ярлыки должны быть в меню (Параметры). Может так попробовать (хуже не будет).
sudo apt-get purge openjdk*
sudo apt-get autoremove
Потом
sudo apt-key adv --keyserver keys.gnupg.net --recv-keys 5CB26B26
echo "deb http://www.duinsoft.nl/pkg debs all" | sudo tee -a /etc/apt/sources.list.d/duinsoft.list
sudo apt-get update
sudo apt-get install update-sun-jre
Ну а там в меню, в Параметрах.
Решено: 129
04 фев 2018, 17:22
То что ставится через apt - старье
apt policy eclipse
eclipse:
  Установлен: (отсутствует)
  Кандидат:   3.8.1-8
  Таблица версий:
     3.8.1-8 500
        500 http://mirror.yandex.ru/ubuntu xenial/universe amd64 Packages
        500 http://mirror.yandex.ru/ubuntu xenial/universe i386 Packages
нет даже на офф-сайте http://wiki.eclipse.org/Older_Versions_Of_Eclipse
Удали пакет sudo apt purge eclipse.
То что ставил по первому способу из статьи удали все папки руками.
А затем попробуй сделать все сначала первым способом
svtv1
04 фев 2018, 17:28
darkfenix
И это старьё, только поставил?
cat2cat
04 фев 2018, 17:31
svtv1 писал(а):
04 фев 2018, 17:19
Потом
sudo apt-get update
так начал запускаться 1ый вариант через apt и ошибку не выдает
но запускается только через терминал или alt+f2
ярлыков нет
к тому же я бы хотел не 3.8 eclipse
а новый oxygen за 12.2017
cat2cat
04 фев 2018, 17:32
04 фев 2018, 17:22
https://itmages.ru/image/view/6446960/74eb2370
cat2cat
04 фев 2018, 17:36
svtv1 писал(а):
04 фев 2018, 17:28
сейча так выдает
idea@cat ~ $ java -version
java version "1.8.0_161"
Java(TM) SE Runtime Environment (build 1.8.0_161-b12)
Java HotSpot(TM) 64-Bit Server VM (build 25.161-b12, mixed mode)
cat2cat
04 фев 2018, 17:41
как все вернуть назад? и установить JDK 9 и eclipse oxygen за декабрь 2017?
Решено: 129
04 фев 2018, 17:49
Удалить все что наставил.
Взять первый вариант установки из той статьи что ты тут указывал, только заменить sudo apt install openjdk-7-jdk на sudo apt install openjdk-9-jdk
svtv1
04 фев 2018, 17:59
Попробуй так
потом
sudo apt install openjdk-9-jdk-headless
Но почему в меню не кажет
