Управление вращением куллера на ноутбуке
wanoska
Благодарил (а): 40 раз
27 апр 2017, 14:20
Всем привет, имеется ноутбук toshiba satellite c660d-a2k
System:    Host: wanoska Kernel: 3.16.0-4-amd64 x86_64 (64 bit gcc: 4.8.4)
           Desktop: N/A Distro: Debian GNU/Linux 8
Machine:   System: TOSHIBA product: Satellite C660D v: PSC20R-01501ERU
           Mobo: TOSHIBA model: PWWBE v: 1.00
           Bios: TOSHIBA v: 1.60 date: 01/10/2012
CPU:       Dual core AMD E-450 APU with Radeon HD Graphics (-MCP-) cache: 1024 KB
           flags: (lm nx sse sse2 sse3 sse4a ssse3 svm) bmips: 6583
           Clock Speeds: 1: 1650 MHz 2: 1650 MHz
Graphics:  Card: Advanced Micro Devices [AMD/ATI] Wrestler [Radeon HD 6320]
           bus-ID: 00:01.0
           Display Server: X.Org 1.16.4 drivers: ati,radeon (unloaded: fbdev,vesa)
           Resolution: 1366x768@59.99hz
           GLX Renderer: Gallium 0.4 on AMD PALM
           GLX Version: 3.0 Mesa 10.3.2 Direct Rendering: Yes
Audio:     Card Advanced Micro Devices [AMD/ATI] SBx00 Azalia (Intel HDA)
           Sound: Advanced Linux Sound Architecture v: k3.16.0-4-amd64
Network:   Card-1: Qualcomm Atheros AR9285 Wireless Network Adapter (PCI-Express)
           driver: ath9k bus-ID: 02:00.0
           IF: wlan1 state: up mac: <filter>
           Card-2: Realtek RTL8101E/RTL8102E PCI Express Fast Ethernet controller
           driver: r8169 v: 2.3LK-NAPI port: e000 bus-ID: 01:00.0
           IF: eth1 state: down mac: <filter>
Drives:    HDD Total Size: 500.1GB (9.5% used)
           ID-1: /dev/sda model: WDC_WD5000LPVX size: 500.1GB
Partition: ID-1: / size: 19G used: 4.7G (28%) fs: ext4 dev: /dev/sda1
           ID-2: /home size: 437G used: 37G (9%) fs: ext4 dev: /dev/sda3
           ID-3: swap-1 size: 3.87GB used: 0.00GB (0%) fs: swap dev: /dev/sda5
Sensors:   System Temperatures: cpu: 49.8C mobo: N/A gpu: 49.0
           Fan Speeds (in rpm): cpu: N/A
Info:      Processes: 153 Uptime: 1:08 Memory: 718.8/3565.9MB
           Init: systemd runlevel: 5 Gcc sys: 4.9.2
           Client: Shell (bash 4.3.301) inxi: 2.1.28
куллер постоянно крутится на полную, lm sensors говорит
radeon-pci-0008
Adapter: PCI adapter
temp1:        +46.0°C  (crit = +120.0°C, hyst = +90.0°C)
k10temp-pci-00c3
temp1:        +46.9°C  (high = +70.0°C)
                       (crit = +99.0°C, hyst = +92.0°C)
pwmconfig говорит
# pwmconfig revision 6166 (2013-05-01)
This program will search your sensors for pulse width modulation (pwm)
controls, and test each one to see if it controls a fan on
your motherboard. Note that many motherboards do not have pwm
circuitry installed, even if your sensor chip supports pwm.
We will attempt to briefly stop each fan using the pwm controls.
The program will attempt to restore each fan to full speed
after testing. However, it is ** very important ** that you
physically verify that the fans have been to full speed
after the program has completed.
/usr/sbin/pwmconfig: There are no pwm-capable sensor modules installed
я так понимаю не установлены модули датчиков на оф.сайте debian говорят "Если датчики обнаружить не удалось, то необходимо обновить ядро и установить более свежую lm-sensors. " но мне кажется что это не поможет, есть какие мысли у вас товариши.
P.S. Извиняюсь что не много не по теме форума
wanoska
управление вращением куллера на ноутбуке
27 апр 2017, 14:29
symon2014, делал после установки lm-sensors
wanoska@wanoska:~$ sensors --version
sensors version 3.4.0 with libsensors version 3.3.5
wanoska@wanoska:~$ sudo sensors-detect
# sensors-detect revision 6284 (2015-05-31 14:00:33 +0200)
# System: TOSHIBA Satellite C660D [PSC20R-01501ERU] (laptop)
# Board: TOSHIBA PWWBE
# Kernel: 3.16.0-4-amd64 x86_64
# Processor: AMD E-450 APU with Radeon(tm) HD Graphics (20/2/0)
This program will help you determine which kernel modules you need
to load to use lm_sensors most effectively. It is generally safe
and recommended to accept the default answers to all questions,
unless you know what you're doing.
Some south bridges, CPUs or memory controllers contain embedded sensors.
Do you want to scan for them? This is totally safe. (YES/no): y
Module cpuid loaded successfully.
Silicon Integrated Systems SIS5595... No
VIA VT82C686 Integrated Sensors... No
VIA VT8231 Integrated Sensors... No
AMD K8 thermal sensors... No
AMD Family 10h thermal sensors... No
AMD Family 11h thermal sensors... No
AMD Family 12h and 14h thermal sensors... Success!
(driver `k10temp')
AMD Family 15h thermal sensors... No
AMD Family 16h thermal sensors... No
AMD Family 15h power sensors... No
AMD Family 16h power sensors... No
Intel digital thermal sensor... No
Intel AMB FB-DIMM thermal sensor... No
Intel 5500/5520/X58 thermal sensor... No
VIA C7 thermal sensor... No
VIA Nano thermal sensor... No
Some Super I/O chips contain embedded sensors. We have to write to
standard I/O ports to probe them. This is usually safe.
Do you want to scan for Super I/O sensors? (YES/no): y
Probing for Super-I/O at 0x2e/0x2f
Trying family `National Semiconductor/ITE'... No
Trying family `SMSC'... No
Trying family `VIA/Winbond/Nuvoton/Fintek'... No
Trying family `ITE'... No
Probing for Super-I/O at 0x4e/0x4f
Some hardware monitoring chips are accessible through the ISA I/O ports.
We have to write to arbitrary I/O ports to probe them. This is usually
safe though. Yes, you do have ISA I/O ports even if you do not have any
ISA slots! Do you want to scan the ISA I/O ports? (YES/no): y
Probing for `National Semiconductor LM78' at 0x290... No
Probing for `National Semiconductor LM79' at 0x290... No
Probing for `Winbond W83781D' at 0x290... No
Probing for `Winbond W83782D' at 0x290... No
Lastly, we can probe the I2C/SMBus adapters for connected hardware
monitoring devices. This is the most risky part, and while it works
reasonably well on most systems, it has been reported to cause trouble
on some systems.
Do you want to probe the I2C/SMBus adapters now? (YES/no): y
Using driver `i2c-piix4' for device 0000:00:14.0: ATI Technologies Inc SB600/SB700/SB800 SMBus
Module i2c-dev loaded successfully.
Next adapter: SMBus PIIX4 adapter at 0b00 (i2c-0)
Do you want to scan it? (YES/no/selectively): y
Client found at address 0x50
Probing for `Analog Devices ADM1033'... No
Probing for `Analog Devices ADM1034'... No
Probing for `SPD EEPROM'... Yes
(confidence 8, not a hardware monitoring chip)
Probing for `EDID EEPROM'... No
Next adapter: SMBus PIIX4 adapter at 0b20 (i2c-1)
Next adapter: Radeon i2c bit bus 0x90 (i2c-2)
Do you want to scan it? (yes/NO/selectively): y
Next adapter: Radeon i2c bit bus 0x91 (i2c-3)
Next adapter: Radeon i2c bit bus 0x92 (i2c-4)
Next adapter: Radeon i2c bit bus 0x93 (i2c-5)
Next adapter: Radeon i2c bit bus 0x94 (i2c-6)
Next adapter: Radeon i2c bit bus 0x95 (i2c-7)
Next adapter: Radeon i2c bit bus 0x96 (i2c-8)
Next adapter: Radeon i2c bit bus 0x97 (i2c-9)
Now follows a summary of the probes I have just done.
Just press ENTER to continue:
Driver `k10temp' (autoloaded):
* Chip `AMD Family 12h and 14h thermal sensors' (confidence: 9)
No modules to load, skipping modules configuration.
Unloading i2c-dev... OK
Unloading cpuid... OK
27 апр 2017, 14:34
Выше ссылку добавил. Как то упражнялся, не помню точно, у меня работало. Поскольку у меня десктоп, забил и забыл.
wanoska
27 апр 2017, 14:39
symon2014, я по этой ссылке изначально пробовал в шапке выхлоп pwmconf. вот на этом месте и тупик к сожалению
wanoska
27 апр 2017, 14:41
wanoska@wanoska:~$ sudo systemctl start lm_sensors
Failed to start lm_sensors.service: Unit lm_sensors.service failed to load: No such file or directory.
SemenSinchenko
27 апр 2017, 15:14
wanoska писал(а): куллер постоянно крутится на полную
1. Это может показаться глупым, я извиняюсь заранее, но в BIOS точно не выставлена галка типа "Fan always ON"?
2. Будучи счастливым обладателем впаянного процессора от AMD я могу сказать, что иногда эта проблема (не распознавание вентилятора) может не решаться - мне вот так и не удалось ее решить, но у меня вентилятор работает с перерывами.
3. Вот здесь советуют попробовать добавить acpi_enforce_resources=lax в /etc/default/grub, но это, как я понял, если ноут горячий, а вентилятор не включается. В Вашем случае проблема именно в сенсорах похоже...
4. Есть идея добавить драйвер w83627ehf который вроде бы помогал в схожих ситуациях со слов людей в гугле, но на оооочень старых ядрах. Попробуйте выполнить sudo modprobe w83627ehf, хотя по моему это не поможет, ибо в выводе sensors-detect у Вас Trying family `VIA/[u]Winbond[/u]/[u]Nuvoton[/u]/Fintek'... No. Он по идее должен был их найти и сам предложить загрузить нужный модуль.
wanoska
27 апр 2017, 15:28
SemenSinchenko,
1. в BIOS вообще нет не чего с FAN
3. советуют добавить в kernel, но у меня нет этого пункта
# /boot/grub/grub.cfg.
GRUB_DEFAULT=0
GRUB_TIMEOUT=0
GRUB_CMDLINE_LINUX_DEFAULT="quite"
GRUB_CMDLINE_LINUX="init=/sbin/e4rat-preload"
#GRUB_TERMINAL=console
#GRUB_GFXMODE=640x480
#GRUB_DISABLE_LINUX_UUID=true
#GRUB_DISABLE_RECOVERY="true"
#GRUB_INIT_TUNE="480 440 1"
4.
modprobe: ERROR: could not insert 'w83627ehf': No such device
SemenSinchenko
27 апр 2017, 15:37
wanoska, GRUB_CMDLINE_LINUX="acpi_enforce_resources=lax", подробнее тут
Естественно через пробел с e4rat
wanoska
27 апр 2017, 17:04
а может быть вариант что ядро не поддерживает датчики этой материнки? Либо на ней просто нет тахометра?
SemenSinchenko
27 апр 2017, 17:53
wanoska, может. У меня такое было на первом ноуте - в Debian (с ядром 2.4...) кулер имел всего два режима - работать и не работать и эксплуатация ноута сводилась к следующему: включаешь ноут, ждешь пока он нагреется до реально горячего (кулер все равно не включался), потом перезагружаешься, кулер включался где то на старте, еще до окна Grub и уже потом не выключался совсем. Причем проблемы не было на бубунте с более свежим ядром и Windows.
Решение с acpi_enforce_resources=lax я так понимаю не помогло?
А может ядро обновить из jessie-backports?
apt-get install -t jessie-backports linux-image linux-image-amd64
или даже ручками собрать последнее, или это принципиально именно 3.16?
Еще вот эта тема наводит на мысль попробовать по управлять энергосбережением через laptop-mode или TLP, или даже через штатные средства окружения. Там пробовали крутить? Кстати вентилятор и от розетки и от батареи на максимум крутит?
wanoska
27 апр 2017, 18:22
SemenSinchenko, ядро ещё новее, а железо старое, я думаю наоборот выпиливают из него старое железо, laptop-mode сейчас гляну
SemenSinchenko
28 апр 2017, 10:01
wanoska писал(а): ядро ещё новее
Значит я что-то не понял, просто в первом посте Kernel: 3.16.0-4...
Решено: 215
Благодарил (а): 815 раз
28 апр 2017, 10:16
wanoska, на acpi -V он тебе что-то перечислит из кулеров?
wanoska
28 апр 2017, 10:42
Chocobo, нет, вот выхлоп
Battery 0: Unknown, 0%
Battery 0: design capacity 4500 mAh, last full capacity 1828 mAh = 40%
Adapter 0: on-line
Cooling 0: LCD 0 of 7
Cooling 1: Processor 0 of 3
Cooling 2: Processor 0 of 3
я имел ввиду что нет смысла ставить более новое ядро
Решено: 31
Благодарил (а): 1688 раз
21 фев 2018, 22:34
wanoska, так и не докопался до истины?
Решено: 31
21 фев 2018, 22:35
28 апр 2017, 10:16
$ acpi -V
Battery 0: Full, 100%
Battery 0: design capacity 3871 mAh, last full capacity 2318 mAh = 59%
Adapter 0: on-line
Thermal 0: ok, 59.0 degrees C
Thermal 0: trip point 0 switches to mode critical at temperature 97.0 degrees C
Thermal 0: trip point 1 switches to mode passive at temperature 95.0 degrees C
Cooling 0: Processor 0 of 10
Cooling 1: Processor 0 of 10
Cooling 2: Processor 0 of 10
Cooling 3: Processor 0 of 10
Cooling 4: intel_powerclamp no state information available
Cooling 5: Processor 0 of 10
Cooling 6: Processor 0 of 10
Cooling 7: Processor 0 of 10
Cooling 8: x86_pkg_temp no state information available
Cooling 9: Processor 0 of 10
выделенное то что надо?
svtv1
Благодарил (а): 39 раз
22 фев 2018, 00:28
Да не вы не туда роете, куллер норм. Ведь до этого он работал :hm: . Но вдруг чудесным образом взбесился????
Походу wanoska ты нам чего то не договорил(а). Давай колись, с чего все началось (там и закончится "Вассаби") :help: .
Решено: 31
22 фев 2018, 00:45
svtv1, Да я для себя копаю, хочу или вручную задать скорость или подправить термоконфиги, а то сидя у батареи и под руками бук с 84°С ваще не кайф... При этом вентиль явно не на полную крутит... Пока что-то ни через нвидиа, ни через pwm доступа получить к контролю не получается...
